Angular momentum and rotational energy
The discussion revolves around a physics homework problem involving a spinning carousel where a person sits on it, affecting its angular momentum and kinetic energy. The key points include the conservation of angular momentum, which allows for the calculation of the new angular speed after the person sits down. The correct approach for calculating the change in kinetic energy involves considering the kinetic energy of the carousel before and after the person sits on it, specifically focusing on the carousel's kinetic energy rather than the total system's energy. A misunderstanding about the problem's requirements led to confusion regarding the formulas used for kinetic energy calculations. Clarification on these points helped resolve the confusion and improve understanding of the problem.
starstruck_
A school playground has a carousel, which is simply a circular platform that can rotate around its center axis with negligible friction. This carousel has radius r=1.6 m and rotational inertia I= 177m^2kg. Suppose you are standing beside the carousel which is already spinning at w=0.47 revolutions per second, and then you suddenly sit on it, at the outer edge. Your mass is m= 98 kg.
(a) Calculate the new angular speed.
(b) Calculate the change in kinetic energy of the carousel.
(c) Calculate your change in kinetic energy.
L= Iw
I = mr^2
Rotational kinetic energy: Krotational =1/2 Iw^2
I know that angular momentum is conserved so I can use that to solve for the new angular velocity.
L1= L2
L1 = Iw
L2 = (I +mr^2)wnew I am using I +mr^2 for the new inertia because when you sit down, there is rotational inertia for you added onto the rotational inertia that the carousel already had. That multiplied by the new angular velocity will give you angular momentum.
Since angular momentum is conserved, L1= L2, and so, Iw = (1+ mr^2)wnew
therefore, Iw/(1_mr^2) = wnew
for kinetic energy, there is only rotational kinetic energy present since the carousel is rotating in place.
K1 = 1/2Iw^2
K2 = 1/2 (I+ mr^2)wnew^2
change = 1/2 (1+ mr^2)wnew^2 - 1/2Iw^2 Your change in kinetic energy : This, I'm not really sure about - I want to say that your change in kinetic energy would equal to the kinetic energy that the carousel is moving at once you sit on it . We do these questions online and in steps - we interpret the question ( where I determined that angular momentum is conserved) and if you don't get a step right, it won't let you go to the next step. After interpret, is develop where you develop your formulas using existing formulas - which is what I am on right now. It won't accept my answers and I'm not sure what is wrong, any help would be appreciated! Thanks :)
EDIT: I asked a friend and she ended up doing :
change = 1/2 Iwnew^2 - 1/2Iw^2
Instead of
change = 1/2 (1+ mr^2)wnew^2 - 1/2Iw^2 Not sure why though?
she used 1/2mr^2wnew^2 -didn’t add the rotational inertia of the carousel, just the rotational inertia of you.
L= Iw
I = mr^2
L1= L2
L1 = Iw
That might be correct in intent, but I'm not sure how to interpret what you wrote. You are using a '1' (as in the numeral "one") in there. Is that supposed to be the letter "I" (for moment of inertia)? Also there's an underscore that probably should be something else.
K1 = 1/2Iw^2
change = 1/2 (1+ mr^2)wnew^2 - 1/2Iw^2Your change in kinetic energy : This, I'm not really sure about - I want to say that your change in kinetic energy would equal to the kinetic energy that the carousel is moving at once you sit on it .We do these questions online and in steps - we interpret the question ( where I determined that angular momentum is conserved) and if you don't get a step right, it won't let you go to the next step. After interpret, is develop where you develop your formulas using existing formulas - which is what I am on right now. It won't accept my answers and I'm not sure what is wrong, any help would be appreciated! Thanks :)
Instead of
The problem statement (as you wrote it above), specifically part b), asks for the change of the kinetic energy of the carousel itself -- not the total change in kinetic energy.
collinsmark said:
That might be correct in intent, but I'm not sure how to interpret what you wrote. You are using a '1' (as in the numeral "one") in there. Is that supposed to be the letter "I" (for moment of inertia)? Also there's an underscore that probably should be something else.The problem statement (as you wrote it above), specifically part b), asks for the change of the kinetic energy of the carousel specifically -- not the total change in kinetic energy.
Ohhhhhhhhhhhhhhhh rip my reading comprehension skills :’)
THANK YOU!
The third one makes sense now too!
Likes collinsmark
