How High Will the Unattached Ball Rise After the Collision?
The discussion revolves around a physics problem involving two 5.00-kg balls and a uniform bar pivoting at its center. The key focus is on applying the conservation of angular momentum to determine how high the unattached ball will rise after a collision with the bar. Participants clarify that while the falling ball does exert a torque, it is not considered an external torque when analyzing the entire system. The approach suggested involves treating the collision similarly to a linear momentum problem but applying it in an angular context. The conversation emphasizes understanding the principles of momentum conservation in rotational dynamics.
boredaxel
A 5.00-kg ball is dropped from a height of 12.0 m above
one end of a uniform bar that pivots at its center. The bar has mass
8.00 kg and is 4.00 m in length. At the other end of the bar sits
another 5.00-kg ball, unattached to the bar. The dropped ball sticks
to the bar after the collision. How high will the other ball go after
the collision?
L= r X p
L = I \omega
mgh =1/2 mv^2
The solution seems to require the conservation of angular momentum. But i am not sure how angular momentum could be conserved? Doesnt the weight of the falling ball provide a net external torque to the system?
Welcome to PF!
boredaxel said:
A 5.00-kg ball is dropped from a height of 12.0 m above one end of a uniform bar that pivots at its center.
The bar has mass 8.00 kg and is 4.00 m in length. At the other end of the bar sits another 5.00-kg ball, unattached to the bar.
The dropped ball sticks to the bar after the collision.
How high will the other ball go after the collision?
Hi boredaxel! Welcome to PF! :smile:
Yes, it does provide a torque, but that doesn't matter, because it isn't an external torque …
at least, if you consider the whole system together, it isn't external! :wink:
Angular momentum, like momentum, is always conserved.
Hint: treat this exactly the same way as you would if the ball was hitting a block with another ball directly the other side …
you'd use conservation of (linear) momentum, and v1f = v2f, wouldn't you?
Well, do the same, except … "angularly"! :biggrin:
Likes Mitchel Haas
