Angular momentum, Spin and satelites
The discussion centers on the energy dynamics of satellites as they approach a star, specifically addressing where energy goes when a satellite's distance from a star decreases. It highlights that as a satellite moves closer, potential energy converts into kinetic energy, while angular momentum remains constant. Participants clarify that changes in kinetic energy are balanced by changes in potential energy, emphasizing that energy conservation applies even in non-circular orbits. Misunderstandings about angular momentum and potential energy formulas are addressed, with the conclusion that assuming elliptical orbits resolves the initial confusion. Ultimately, the conversation reinforces the principles of energy conservation in orbital mechanics.
Mahbod|Druid
Hello
we know that satelites turn around a star in ellipse path (or parabola/hyperbola)
I wanted to know where does the energy go when a satelite comes closer to a Star
we have angular momentum for the satelite itself and another angular momentum for spin of satelite
and we know that angular momentum = Constant
because f(r) = k , f(\theta)=0
but if we calculate the velocity of satelite at diffrent distances we realize that angular momentum will give one answer which says that some Energy goes somewhere but where?
changes to spin ? ( Iw2/2 )
but angular momentum of spin must be constant too ?
Thanks
Review Kepler's second law: A line drawn from the Sun to the Earth describes equal areas in equal times.
Potential energy.
Thanks for the reply
but Kepler's law is equal to Angular momentum
and when a satelite comes closer to star potential energy turns into kinetic energy
satelites comes closer to star very tiny distance in circular orbits :
from angular momentum we have :
Iw1 = Iw2 => mR21w1 = mR22w2
R2 = R1 - dR
so:
R21w1 = R21w2 - 2R1dRw2
and : w2 = w1 \frac{R1}{R1 - 2dR}
and because of circular orbits : W*R = Velocity
w2 R2 = V2 = w1(R1 - dR) \frac{R1}{R1 - 2dR}
there we calculated Velocity by momentum
now let's calculate it with Energy : (dR is very small so we can get GM/R2 constant=Q)
m = mass of satelite
mQdR = \Delta Kinetic energy
V2 = \sqrt{V^2 + 2QdR} = V1 + QdR/V1
and here we calculated velocity from work done by Gravity field
and we see 2nd calculation depens on the mass of Star "Q = GM/R2)
calculation is not 100% correct but it will depend on mass of central star anyway ...
so where does the energy go ? into Spin ? then why is not angular momentum of satelite constant
You made several mistakes in the above. Some of them are
1. Assuming v=\omega r
2. Ignoring the change in potential energy
3. Using the wrong formula for potential energy.
You were told in post 3 that the change in kinetic energy is balanced by a change in potential energy. You cannot assume that the potential energy remains constant.
One way to express conservation of energy with orbits is with the vis-viva equation,
v^2 = GM_{\text{sun}}\left(\frac 2 r - \frac 1 a\right)[/itex]
<br /> <br /> <br /> 1. Assuming v=\omega r<br /> when we imagine orbits are Circular this can be right <br /> <br /> 2. <b>Ignoring the change in potential energy</b><br /> mQdR = value of changed ptential<br /> when we throw a ball from height H1 and we want to calculate the speed at Height H2 while H2 is not far from H1 like 1000 meter we calculate like :<br /> mg(H2 - H1) = -(mV<sub>2</sub>^2 - mV<sub>1</sub>^2)/2 where g is constant = 9.8<br /> i named Q as g where dR --&gt; 0<br /> (i know that we assume R --&gt; 1000000000 , potential = 0 and as we come closer to star potential gets more minus but for easier caculation we can use mg*delta(H) )<br /> <br /> 3. Using the wrong formula for potential energy.<br /> still we can say GMsun/R^2 = GMsun/(R + dR)^2<br /> <br /> <br /> &quot;You were told in post 3 that the change in kinetic energy is balanced by a change in potential energy&quot;<br /> as i have calculated above all the change in potential energy doesn&#039;t turn into Velocity<br /> Angular momentum does NOT depend on Mass of sun but potential energy does ... <br /> <br /> <br /> v^2 = GM_{\text{sun}}\left(\frac 2 r - \frac 1 a\right)<br /> <br /> i have no idea what &quot;a&quot; is :-S<br /> <br /> <br /> <br /> <br /> however gravity potential is not like a invisible spring it just depens the distance from Sun<br /> so all changes in potential turns into Work<br /> so where does the energy go ? since Angular momentum = constant ?
You are investigating a problem where the radial distance changes. You cannot assume circular orbit conditions for a non-circular orbit.
The correct equation for potential energy is P=-\,GM/R. You are using the equation for acceleration.
i have no idea what "a" is :-S
This is very telling. "a" is the semi-major axis of the orbit.
Rather than coming in, guns a blazing, claiming "energy is not conserved" you would have better served yourself by posting your analysis and asking "what have I done wrong?"
You have been told several times now that energy is conserved. One last time: Changes in kinetic energy are balanced by opposite changes in potential energy.
Aha i think i got it ... !
this caused the problem assuming satelite changes its orbit without a close path caused the problem
if we assume ellipsal orbit all things will be right ...
thanks :D
