Angular Velocity and Acceleration
The discussion focuses on determining the velocity and acceleration of point C and the angular acceleration of link BC, given the angular velocity and acceleration of link AB. The known values include the angular velocity w as -2k and angular acceleration α as 2k, with point A having zero velocity and acceleration. The user has calculated point B's velocity as -j but struggles to relate this to link BC's angular parameters. Attempts to apply the equation for acceleration have not yielded a valid solution. The conversation highlights the complexities of linking angular motion to Cartesian vectors in this context.
nathan8
Link AB has angular velocity and angular acceleration as shown. Determine the velocity and
acceleration of point C and the angular acceleration of link BC at this instant. Express them as
Cartesian vectors. https://www.physicsforums.com/attachments/41853
vA = 0
aA = 0
w= -2k
(alpha) =2k
I have found that the point b has a velocity of -j
Im not sure how to equate this to the angular velocity of BC or the angular acceleration of BC.
I have used tried applying the ac = (alpha) x rc/b - w2rc/b
but this isn't producing any solution
Invalid attachment.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
