Angular velocity and angular momentum
The discussion focuses on calculating the angular velocity of a turntable after a small ball is caught by it. The initial angular momentum of the turntable and the ball is set equal to the final angular momentum after the collision. The correct approach involves using the moment of inertia for both the turntable and the ball, treating the ball as a point particle for this calculation. The final angular velocity is determined to be 1.33 rad/s, which matches one of the provided answer choices. Participants clarify the importance of using the correct moment of inertia and ensure the calculations align with the principles of conservation of angular momentum.
Northbysouth
A turntable has a radius of 0.80 m and a moment of inertia of 2.00 kg • m2. The turntable is rotating with an angular velocity of 1.50 rad/s about a vertical axis though its center on frictionless bearings. A very small 0.40-kg ball is projected horizontally toward the turntable axis with a velocity of 3.00 m/s and is moving directly towards the center of the table. The ball is caught by a very small and very light cup-shaped mechanism on the rim of the turntable (see figure). What is the angular velocity of the turntable just after the ball is caught
L= Iw
The inertia of the turntable = 2.0 kgm^2
The inertia of a solid sphere = 2/5*M*R^2
Li = initial angular momentum
Lf = final angular momentum (momentum after the ball is caught)
Lid = initial angular momentum of the disc
Lip = initial angular momentum of the particle
Lfd = final angular momentum of the disc
Lfp = final angular momentum of the particle
wft = angular velocity of the turntable after the ball is caught
I assumed that Li = Lf
Li = Lid + Lip
Li = 2.0kg*1.50 rad/s + 0
Li = 3.50 kgm^2
Similarly, I thought that:
Lf = Lfd + Lfp
Lf = 2.0kgm^2/s*wft + 2/5*0.4kg*0.80^2*wft
3.50kgm^2/s = 2.1024wft
wft = 1.66476 kgm^2/s
As you can see this isn't an answer choice. Is it wrong for me to assume that the angular velocity of the particle after it is caught is the same as that of the turntables angular velocity?
I'm not too sure if I'm right, but hopefully this is one of the answer choices.
After the collision, the ball and the turntable should be turning together.
Ii*Wi=If*Wf
You can just add up the moments of inertia, so:
If=Turntable Moment + Ball Moment
The ball is small enough that we can treat it like a point particle (I see that you multiplied by 2/5, but that only works whenever the axis of rotation is through the diameter of the sphere, in this case the axis of rotation is a radius r from the ball), so ball moment=m*r^2
2.00*1.5=(2.00+0.4*0.8^2)*Wf
Wf=3/(2.256)
Wf=1.33
Please let me know if that's an answer.
Yes that is an answer. Thank you
The choices, which I forget to put in my original post are:
A) 1.33 rad/s
B) 0.75 rad/s
C) 0.30 rad/s
D) 0.50rad/s
E) 0.94 rad/s
Alright cool.
It looks like you just accidentally multiplied 2*1.5 incorrectly, and used the wrong moment of inertia for the ball.
