Angular velocity and moment of inertia
6 replies · 32K views
kikidoll
Could you let me know if my answers are correct?
A light rope is wrapped several times around a large wheel with a radius of 0.400m. The wheel rotates in frictionless bearings about a stationary horizontal axis. The free end of the rope is tied to a suitcase with a mass of 0.15kg. The suitcase is released from rest at a height of 4.00m above the ground. The suitcase has a speed of 3.50 m/s when it reaches the ground.
Calculate:
A) the angular velocity of the wheel when it reaches the ground and
B) the moment of inertia of the wheel
A) angular velocity (w) = speed/radius
B) mgh = 1/2 mv2 + 1/2Iw2
After using these equations I found angular velocity to be 8.75 rad/s and the moment of inertia to be 12.9 kg*m2.
Correct or incorrect? Thanks for you help.
Calculate:
With ω = v/r then 8.75 looks ok.
But your I looks a little large.
m*g*h is total energy to start with dividing by ω2 where ω2 looks a lot bigger than m*g*h doesn't look right.
Thanks for the reply. I also though I was rather large, but with my calculations that's what I ended up getting... strange.
I think you've done something wrong.
Maybe show your numbers and how you got there.
A) w = v/r = (3.50)/(0.400) = 8.75 rad/s
B) Ki + Ui = Kf + Uf
Ki and Uf = 0
Ui = Kf
(15)(9.8)(4) = 1/2 (15)(3.5)2 + 1/2 (I) (8.75)2
588 = 91.9 + 38.3(I)
496.1 = 38.3(I)
I = 12.9 kgm2
Ki and Uf = 0
Ui = Kf
496.1 = 38.3(I)
I = 12.9 kgm2
Whoa. SI units please.
m = .15kg
Oh my gosh I can't believe I did that *facepalms*
Thanks for your help, I really appreciate it
