Angular velocity by time variable force
The discussion focuses on calculating the time required for a disk to reach an angular velocity of 200 revs/sec under the influence of a time-variable force, F(t)=20+t+5t^2. Participants clarify the use of equations related to torque, moment of inertia, and angular acceleration, emphasizing the importance of integrating the force function correctly. It is noted that substituting θ for ωt is mathematically incorrect unless ω is constant, as θ should be expressed as the integral of ω over time. The integration can be performed as an indefinite integral, allowing for the determination of the time without needing specific limits. The conversation highlights the need for careful application of calculus in physics problems.
Totally
Force represented by F(t)=20+t+5t^2 [N] acts upon the rim of a disk. How much time has to pass before the disk has angular velocity of 200 revs\sec? R and I are known.
\begin{equation*}
\tau=I\alpha
\end{equation*}
\begin{equation*}
\tau=R \times F
\end{equation*}
\begin{equation*}
I=\frac{1}{2}mR^2
\end{equation*}
\begin{equation*}
\alpha=\frac{R}{I}F
\end{equation*}
\begin{equation*}
\omega=\frac{R}{I}\int_{0}^{t} F(t)dt
\end{equation*}
I have same variable in my upper integration limit as in the function. So I'm thinking of integrating F(t) twice to get the distance and instead of writing it as θ, write it as ωt so it looks like the following
\begin{equation*}
\omega t=\frac{R}{I}∫∫F(t)dt
\end{equation*}
Then divide by t and solve the cubic. Does that seem like a legitimate move?
It seems legitimate for getting ω, but expressing θ as ωt is not correct. However, if θ were put in place of ωt on the left side of your final equation, the equation would be correct. However, the problem is not asking for θ. It is just asking for the time t at which ω reaches a certain value. This can be determined exclusively with your first equation for ω.
Chet
Likes Totally
Oh wow, I can just integrate F(t) as indefinite integral, can't I? I don't need the 0 and t limits because the integration constant I'll be getting will mean initial velocity, which is zero in this case.
Also, why is it wrong mathematically to sub θ for ωt? Is it because I'm supposed to be integrating t on the right side?
I would write the equation as
$$\omega=\frac{R}{I}\int_{0}^{t} F(t')dt'$$
where t' is a dummy variable of integration. This is actually a definite integral that gives you the value of ω at t'=t.
θ is not equal to ωt unless ω is constant. Otherwise, ##θ=\int_0^t{ω(t')dt'}##, assuming that θ=0 at t = 0.
Chet
