Angular Velocity On Pulley After Variable Force
The discussion revolves around calculating the angular velocity of a pulley subjected to a time-varying tangential force. The force is defined as F = 0.50t + 0.30t², and the initial conditions state that the pulley starts from rest. Participants highlight the need to integrate the force function over the specified time interval to determine the torque and subsequently the angular acceleration. There is confusion regarding the multiplication by time in the initial calculations, which is corrected by emphasizing the integration of the force to find the net torque. Ultimately, the correct approach involves using the integral of the force to accurately compute the angular velocity after 4 seconds.
Jshumate
A pulley having a rotational inertia of 1.1 10-3 kg·m2 about its axle and a radius of 23 cm is acted on by a force, applied tangentially at its rim, that varies in time as F = 0.50t + 0.30t2, where F is in Newtons and t in seconds. If the pulley was initially at rest, find its angular speed after 4.0 s.
(I'm having trouble with Latex so excuse my non-greek)
T = AI
(net torque= angular acceleration*rotational inertia)
w = at
(angular velocity = angular acceleration*time)
T = rF
(torque = length*force)
w = (T)(t)/I
rFt/I = w
I assume I have to integrate the force function over the period of time. The integral of F(t) from 0 to 4 = 10.4.
(10.4 N)(0.23 m)(4 s)/(1.1 10-3kg·m2) = w
w = 8698 rad/s
But this is incorrect. I am not sure how to handle this with the variable force being applied.
w = 8698 rad/s
why did you multiplied by the time?
ehild
T = AI
w = at  dw = a·dt You will need to integrate this.
T = rF
w = (T)(t)/I  dw = ((T)/I)·(dt)  
rFt/I = w  (rF/I)(dt) = dw
w = 8698 rad/s
Some corrections in red above.
\omega-\omega_0=\frac{r}{I}\ \int_0^{\,4} F(t) dt
I don't think this is the integral you did.
No idea why I multiplied by time, thanks guys. :D
