Another electrostatics question.
  • Thread starter Thread starter bitrex
    Electrostatics
The discussion revolves around understanding the calculation of the electric field above a charged disc, specifically the role of Coulomb's law and the cosine of theta in this context. The Pythagorean theorem is used to determine the distance from the charged ring to a point on the Y-axis, denoted as r. The electric field dE from a charge element points away from point P and has both x and z components. The x components cancel out due to symmetry, while the z components contribute to the net electric field, resulting in E cosθ. This explanation clarifies how the electric field is derived from the charged disc configuration.
bitrex
There's no problem as such here, just a bit of confusion I'm having regarding finding the electric field. On the following page, second example, is the equation for finding the electric field above a charged disc http://hyperphysics.phy-astr.gsu.edu/Hbase/electric/elelin.html#c2". I understand how they used the Pythagorean theorem to calculate the distance from the charged ring to the point on the Y axis to find r, but I'm not understanding why Coulomb's law had to be multiplied by the cosine of theta first?
Because the electric field dE due to the element of charge shown in the figure is along r and points away from P. This field has two components, one along z and one along x. The x component is canceled by an element of charge diametrically opposed on the other side of the ring. The z component of the diametrically opposed charge is the same dE cosθ. So when you add all the horizontal components you get zero, but when you add all the z-components you get E cosθ.
