Another simple square root problem
The square root of 25 is 5 because the square root function returns only the positive value. However, when solving the equation x² = 25, both x = 5 and x = -5 are valid solutions, leading to the notation x = ±5. This distinction arises because the square root function and the equation-solving process are different; the former yields only the principal root, while the latter considers both roots. The proper method to solve x² - 25 = 0 involves factoring, which clearly shows both solutions. Therefore, it's essential to recognize that equations can have multiple solutions, unlike the square root function.
dnt
why is the square root of 25 just 5
but when the question x^2 = 25, the answer becomes +/- 5?
whats the logic here? i don't quite get it. thanks.
Square root is a function that returns the positive value only.
When you have the eqn,
X² = 25
then both x=5 and x = -5 are solutions of the eqn,
Which is why you write down the answer as x = +/- 5
If you applied the square root function to x², you would get
Sqrt(x²) = |x|
so its basically a matter of function vs equation?
Solving the equation x^2=25 by taking the square root is a bit sloppy, IMO. What you are really doing is a shortcut for the following:
x^2-25=0
(x-5)(x+5)=0
x-5=0 or x+5=0
x=5[/itex] or x=-5<br /> <br /> When you solve the equation by taking the square root (I should say <b>roots</b>), you have to <i>remember</i> that there are two of them.
More or less, yes.
In general, an equation like x2= a has two solutions.
One is the square root of a: \sqrt{a}.
The other is the negative of the square root of a:-\sqrt{a}.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
