Another Twins Paradox question
  • Context: Graduate
  • Thread starter Thread starter Al68
    Paradox Twins paradox
104 replies · 12K views
RandallB said:
Alan are you working these numbers, would this distance be the length of the measuring rod you were referring to earlier?
At least there is enough here to see that this means the Earth frame can clearly report that t’ = 23.09 years on the traveler clock near Earth is simultaneous with t’ = 5.77 years on the traveler clock near the star. OBVIOUSLY the traveling frame has screwed up synchronization – right?.
BUT Alan, work out the details on that rod length your were thinking about. Where is the Earth in relation to the traveler when t’= 5.77 years?? Once you know where the Earth is at you can have another observer in traveler frame there with a clock at t’=5.77 look over to the Earth to see WHEN that is in the Earth frame.
You shouldn’t be surprised to see that now it is the Earth frame that has lost touch with keeping things synchronized.
An “Asymmetrical disagreement” if you like.
BUT that is not the point.
And nether is which twin in the one way trip here is “really” younger or older!
Einstein’s point here is that what you perceive to be simultaneous between things separated by any distance, even just across the room from your is only within your own frame of reference and is not “real” and does not need to be “real”. IF you demand that some frame be a reference that is best described as a preferred frame of reference as in Lorentz Relativity "LR" not SR.
TO get a better ‘feel’ for these I recommend detailing out accurate “When” and “Where” information in every frame you use for everything used in an exsample. IMO using the ‘ability’ to SEE or OBSERVE clocks at great distances can to easily cause problems in understanding and doesn’t really make sense anyway. With any distance you must have a delayed observation, which is in effect local observer sending a report to you.
Keep working the details and it will get clearer.
Randall,
Although it looks like we've got my point resolved, you seem to be hinting at something else. Is there some other important point to be made here?
Just because I kept trying to redirect the discussion to my point doesn't mean that I'm not aware of other aspects of SR and the Twins Paradox that are more important.
I just didn't want to get sidetracked discussing points that have been addressed extensively in discussions of the Twins Paradox and SR. Are you referring to something else here?
Thanks,
Alan
pervect said:
Al68 said:
I only wanted to make this point because this asymmetry is usually ignored in the Twins Paradox.
Alan
That's because there isn't any.
pervect,
You do not think it's asymmetric that, in the Twins Paradox, one twin travels a longer distance than the other (as measureed in each twin's respective frame)?
Or do you just think that this point is irrelevant or unimportant?
Just curious.
Thanks,
Alan
Al68 said:
pervect,
Just curious.
Thanks,
Alan
I think this point depends on what you and pervect mean by "asymmetry". Usual when physicists talk about symmetries they are talking about the laws of physics, and there is no asymmetry in how the laws of physics work in the two frames. But if you like you can say there is an "asymmetry" in the details of how this particular physical setup appears in the two frames; you don't even really have to get into the times to see this, you can just note that in one frame there's two parts of the system moving and the one in the middle at rest, while in the other frame two parts are at rest and one is moving between them (this 'asymmetry' would be present in the Newtonian version of the problem too).
Al68 said:
Randall
My main concern was that IMO you were correct in looking for additional details related to the twins such as what amounted to the when and where the Earth was when the star saw the traveler arrive. When you were told that some of that information was arbitrary or unknowable I just disagreed and didn’t want you to be sidetracked from following a productive oath of your own choice. For any location and time in a reference frame there is one and only one time and place for it in another defined reference frame. There is no reason you cannot determine that kind helpful information exactly and there is nothing arbitrary in it.
As to “something else here” – that depends on where you want to go beyond the twins.
You can already see from looking at simultaneous events in the earth-star frame you find from complete SR detail it reveals t’= 5.77 and t’= 23.09 are. A paradox you can duplicate from the t’ frame when you looking at the earth-star t frame.
I don’t think your asymmetry point is the key.
Rather you might ask the question, can you trust your frame to correctly tell you if in reality two events separated by distance are simultaneous or not??
Based on what you’ve learned from the Twins, IMO I think you must say NO, and this was Einstein’s point.
Thus moving beyond the twins you might ask: ‘Can I define a "preferred frame" where I can determine if two separated events are REALLY simultaneous?’
Myself, I’m committed to SR and would say NO again, as it would take something very solid for me to reconsider LR “Lorentz Relativity” and the preferred reference frame used there.
So this could be “something else” for you to consider / work on / think about; beyond the twins, maybe open another post after you consider and research it a bit if you like.
You seem to have the twins issue fairly well in hand at this point,
Look on Twins/SR as a tool.
RB
RandallB,
OK, I thought you might be hinting at something else. I had other reasons to pursue my asymmetry point. Which is why I kind of ignored the other points presented. I just wanted to return to your points because it seemed like you were hinting at something else that hasn't been mentioned.
Thanks,
Alan
The reason why many people can't understand the Twins Paradox is simply because it doesn't make sense.
Never fear, I am here to cut through all the cr4p and tell it like it is.
No, I'm no physicist or anything, but even I can see that there's no logic to the explanations offered here or anywhere. Take this one for instance:
http://sciam.com/print_version.cfm?articleID=000BA7D8-2FB2-1E6D-A98A809EC5880105
It's clear from the word go that if you use your conclusion in the proof, you will at the end get the conclusion you were looking for. Let me sum up this especially pathetic attempt:
1.The star is 6 light-years away.
2.The trip takes 10 years (to the one staying at home).
3.The trip feels only like 8 years, because of length contraction.
4.Length contraction = Time Dilation
5.We're supposedly trying to prove time dilation!
6.Return trip, 10 years.
7.Again, feels like 8 years for some reason.
8. 8 + 8 = 16 < 20 = 10 + 10
9.Throw in useless Doppler shifts to confuse tired brains...
10.Conclude that you've proven your point.
Seriously, though, let's define the problem before attemping to solve it shall we?
I'm no expert, so feel free to correct me here but the root of the problem arises from some strange property of light: it passes you by at the constant speed of 299 792 458 m/s. Even when you travel at 100 000 000 m/s relative to your friend, the light passes him by at 299 792 458 m/s and it also passes you by at 299 792 458 m/s. The answer then is time dilation. It allows you to become slower even while you're traveling fast, so that you can see light pass you by at the same rate as before. Notice, however, that there is no acceleration in the problem, which means there shouldn't be in the paradox. Time dilation is a function of speed here, not acceleration.
How do we then define the Twin Paradox without needlessly confusing the issue with accelerations? There's a number of ways we can do that.
1.Suppose that the twins are both astronauts. They each embark on a spaceship. They accelerate at the same rate, for the same predetermined length of time. Afterwards, one of them immediately engages his thrusters in reverse, in order to decelerate, and then to accelerate in the opposite direction, and finally decelerate again in order to stop at the point of origin. Meanwhile, the second one has stopped accelerating, so he is cruising at a uniform velocity. One year later, he does the same decelarating and accelerating maneouvres his bro did earlier. One year later, on final approach, he decelerates the same way his twin did and also ends up at the point of origin. Now they are together again, and the only difference is that one has been static for 2 years, while his bro has been in motion at a constant rate of speed. SR tells us that Time Dilation did occur in this scenario and that consequently one of them will be younger than the other. I challenge anyone to prove such a thing happened. (Edit: I guess they could even have started out in opposite directions...)
2.Another way we can frame the question is by having an alien with an atomick clock, onboard a spaceship in motion coincidentally synchronise it with an atomic clock situated somewhere along his flighpath. I am not suggesting causality, so there shouldn't be a problem with the fact that the 2 atomic clocks were reset at the same exact instant. The question then becomes: when the alien gets a snapshot of the second clock while flying by it, will the clocks still be synchronised?
You should re-read the forum guidelines you signed, espeically the ones about "unfounded attacks on mainstream science will not be tolerated".
But a few things should be obvious even to a non-physicist like yourself.
1) The article does not attempt to "prove" relativity. The article only attempts to explain it.
2) The proof of relativity is not deductive. The proof of relativity is in how well it's theoretical results are confirmed by experiment.
What makes my "attack" unfounded? And how is it an attack on mainstream science? I can see it as an attack on lazy defining of a problem and an attack on equally lazy explanations of a theoretical phenomena.
I've also seen many posts from some users who "wish to argue Relativity's validity, or advertise their own personal theories", that didn't earn a warning about forum guidelines. What's so much worse about mine? Does it make too much sense? Scared? Go ahead and delete it if you must... If you want to stifle intelligent debate...
Not alone, no. The fact that light is measured to travel at the same speed by all observers is a consequence of how Einstein proposed that each observer should define their own coordinate system--using a network of rulers and clocks which are at rest with respect to themselves, with the clocks synchronized using the "Einstein clock synchronization convention", which is based on each observer assuming that light travels at the same speed in all directions in their coordinate system (so two clocks in an observer's system are defined to be synchronized if, when you set off a flash of light at their midpoint, they both read the same time at the moment the light from the flash reaches each one). The rationale for defining each observer's coordinate system this way becomes clear in retrospect, when you see that it is only when you define your coordinates this way that the laws of physics will be observed to work the same way in each observer's coordinate system (this is because the laws of physics have a property known as 'Lorentz-symmetry', the name based on the fact that the different coordinate systems described above will be related to each other by a set of equations known as the 'Lorentz transformation'). You're still free to define your coordinate systems in a different way, but then the laws of physics would take a different form in different observer's frames.
The Einstein clock synchronization is enough to insure that each observer will measure light to travel at a constant speed in all directions, as opposed to faster in some directions than others. But to explain why the magnitude of this constant speed is the same for different observers, you also have to know that each observer will measure the rulers of those moving at velocity v relative to him to shrink by a factor of [tex]\sqrt{1 - v^2/c^2}[/tex] and the ticks of clocks expand by a factor of [tex]1/\sqrt{1 - v^2/c^2}[/tex] (as long as the laws governing the rulers and the clocks have the property of Lorentz-symmetry, it's guaranteed this will happen). So, the fact that all observers measure the speed of light to be constant in all directions and the same from one observer's frame to another's is really a consequence of three things combined: time dilation, length contraction and "the relativity of simultaneity" (meaning that different observers will disagree whether a given pair of events happened 'at the same time' or not) which is a consequence of Einstein's clock synchronization convention. I posted a simple numerical example of how these three factors interact to insure a constant speed of light in this thread, if you're interested.
Yes, in an inertial frame time dilation is always a function of speed--if a clock is traveling at velocity v at a given moment, its rate of ticking will always be [tex]\sqrt{1 - v^2/c^2}[/tex] times the rate of ticking of clocks at rest in that frame at that moment.
It is usually convenient in statements of the twin paradox to just assume the acceleration period is instantaneously brief, so that the twin switches from one velocity to another instantaneously.
Simple, just analyze the problem from the point of view of the inertial frame of the spot where they both departed and later reunited (we can assume it's the earth, say). In this frame, one twin spent only a brief time moving at high velocity (suppose he instantaneously accelerated to 0.8c moving away from the earth, then after 0.01 years instaneously accelerated to 0.8c moving back towards it, then after another 0.1 years he reached Earth again and instantaneously accelerated so he was at rest on earth), while the other spent a whole year moving at high velocity. The first twin's clock was only ticking slow in this frame during the time he was moving relative to the earth, while the other twin's clock was ticking slow during the entire year, so the second twin's clock will have elapsed less time. Using the Lorentz transform, we could analyze this same situation from the point of view of any other inertial frame, and we'd always get the same answer to what the two clocks read when they reunited--I could show you the math if you want.
Just to be clear, are there 2 different clocks in the alien's flightpath, as well as a third atomic clock on the alien's ship? And you're saying the alien's clock reads the same time as the first clock in his path at the moment he passes it, and then you want to know what will happen as he passes the second clock in his path and compares it with his own clock? In this case the answer will depend on which frame the two clocks were synchronized, because again, the "relativity of simultaneity" means that different frames disagree on whether two events (such as two different clocks ticking 12 o clock) happened at the same time or different times. If the two clocks are at rest with respect to each other and synchronized in their own rest frame, then in the alien's rest frame the first clock he passes will be ahead of the second one by a constant amount, and this explains why, even though both clocks are running slower than his, his clock still reads a smaller time than that of the second clock he passes (in the clocks' own frame, this is because the alien's clock was running slow). Again, I could show you a numerical example to explain why both frames make the same prediction about what the clocks read at the moment they pass despite disagreeing about which clock was running slow and whether or not the two clocks in his path were synchronized.
My understanding of the rules is that you are free to say that certain aspects of relativity don't make sense to you, and ask questions about how relativity would explain things, as you did in that long post. What's not allowed is just making definite assertions that relativity is wrong without any room for further discussion or calls for explanation.
Thank you for your replies, JesseM. I also read the other thread you referenced. I understand how, using the Lorentz transformation, one can demonstrate that the Twin in the spaceship ages less.
The problem I have with the whole concept, however, is that, by showing how one twin ages less, the paradox is trying to demonstrate that time dilates when traveling at speeds close to c. Why then is it OK to use a formula that assumes time dilation within our demonstration? It becomes a circular argument.
It's exactly as if I were trying to demonstrate that 5=7 by assuming that 1=3 and demonstrating that 1+4=3+4.
Never fear, I am here to ……… tell it like it is.
How do we then define ……without needlessly confusing accelerations?
They accelerate at the same rate, …..
Afterwards, one of engages his thrusters in reverse, to decelerate,
later, he decelerates the way his twin did and also ends at the point of origin.
I challenge anyone to prove …………….
OH I fear – If that was to remove acceleration confusion – I fear what you might say when you get to something not so simple as SR like GR or QM – I fear a great deal!
Your "attack" is unfounded, because it is irrationality incomplete.
In the Twins Paradox there are no acceleration issues to deal with.
It is easy to eliminate acceleration calculations in relativity.
Just use infinite instantaneous accelerations that take zero time to make transfers.
All reference frames will agree that the time elapse for any object going though such acceleration will slow to zero.
But since it also takes zero time in all reference frames there is also no argument as to when and where it started or ended as measured in any frame from any frame.
They will all agree.
If you can not handle that simple assumption, just use high speed snap shots of clocks with a fresh stop watch attached to each photo image. Then you can track total time for a clock and its images without anything actually having to accelerate anything at all. Just keep track of exactly where and when in each reference frame each image was taken and recorded.
Both methods will give the same agreement with SR, which is the Twins issue is not a paradox at all.
Do the work and you will know it like it is.
Just be sure to be absolutely complete and detailed about the where and when of each event in all three reference frames.
While true that I didn't eliminate acceleration from the sequence of events, I did eliminate it from the equation by having both twins experience the same amount of it.
You say that "In the Twins Paradox there are no acceleration issues to deal with."
JesseM also said we can make the acceleration instantaneous in order to eliminate it from the equation.
Why then is it that in explanations of the Twin Paradox, acceleration always rears its ugly head, by claiming that it can't really be instantaneous after all and some (or all) of the discrepancy between the clocks happens there, or that we have to only consider the worldline of the one who remained in an uniform inertial frame?
Well, the way I arranged the problem, these strategies can no longer be used to avoid the issue.
Thinking of the problem as I stated it, where both experience the same accelerations, the difference between them is only the speed that they are experiencing. Since that is relative, how can you tell which one is moving and thus remaining younger?
Acceleration is not always used to explain the differences in the twin’s ages. As you've already noted, JesseM certainly didn’t use that.
And as you said, when acceleration on the traveling twin is used as the reason for the difference in ages, it is ugly because it is wrong.
Your attack is unfounded because you set up a "straw man" which you then proceed to be demolish.
This is a rather shabby form of debating practice.
The general purpose of this forum is to answer questions that people have about relativity. You are not "asking questions", you are playing silly little debating games.
I don't really believe you for a second when you say that you are attacking the "lazy writers" of that article and not attacking relativity. But I'll pretend that I do, for the sake of politeness.
In that case, I will simply say that it is not the fault of the article that it does not address your particular questions. It was not intended to provide a "proof" of relativity.
So, now let us pretend that you politely asked us - if this article doesn't provide a "proof" of relativity, and that it is not necessarily a bad article for omitting such a "proof", for it never intended to provide such a "proof", where do I find an article that does?
We will then politely answer you that that science does not provide such proofs. Back in the days of Aristotle, it was thought that "man's mind could elucidate all the laws of the universe, by thought alone, without recourse to experimentation"
Nowadays, we know better. Or at least most of us do. If we take your post at face value, you apparently do not know better.
So now we will politely attempt to explain to you that the scientific method is based on doing experiments - not on "proof".
This is really basic stuff. I'll conclude to a link to the wikipeda with some basic introductory info on the scientific method:
http://en.wikipedia.org/wiki/Scientific_method
a link to Aristotle's view on science
http://en.wikipedia.org/wiki/Aristotle#Science
and a suggestion that if you want to debate the foundations of science that you try the philosophy forum and not the relativity forum.
Now, if you ever manage to progress to the question: "What sort of experimental evidence makes us believe in relativity" this would be a resonably good forum to ask such a question. Of course we'd have to believe that you were actually interested in the answer...
I think you're misunderstanding the point of the twin paradox. The original idea of the "paradox" was to show that there was an internal logical inconsistency in the theory of relativity, so that even if you started out assuming the laws of relativity were correct, you would get inconsistent predictions if you analyzed the same situation from the point of view of different reference frames. The basic idea of the paradox is something like "from the Earth twin's point of view, the twin in the rocket is the one moving so his clock will be running slower, therefore he'll have aged less when they reunite; but you could equally well look at things from the point of view of the twin in the rocket, who sees the Earth moving, therefore he should predict the Earth twin will have aged less." The flaw in this argument is that the standard rules of time dilation only work in inertial frames, and the rocket twin does not stick to a single inertial frame (this is true regardless of whether he changes velocities instantaneously or if the acceleration is spread out over a finite period of time). As long as you analyze the paths of both twins from the point of view of an inertial frame, you will always get the same answer to how much each twin will have aged along their entire path, even if you use a frame where the Earth is moving and the twin on the rocket is at rest during one leg of the journey (but in such a frame, the twin on the rocket will have to move even faster than the Earth on the other leg of the journey in order for them to reunite).
If you are looking for actual experimental evidence of time dilation, rather than just arguments for why the theory of relativity is internally consistent, that's a separate subject. There's certainly plenty of experimental evidence, like the longer decay time of particles moving at very high velocities, or the fact that the GPS satellite system is designed to factor time dilation into all its calculations and would not work correctly if time dilation did not exist.
First of all, perv, I did not set up a "straw man". And stop defending that one specific article. It was merely an example. I read multiple articles on the twins paradox, some of which I was directed to from numerous threads on the subject in this forum. There was one that had "faraday" and, I believe, the university of toronto in the url, and another one linked to from the end of that one, for instance. They all claim to be the resolution of the paradox, and none did so satisfactorily in my view. That is why I registered here. Having read a few threads around here, I thought this would be a place where I could possibly get some clarifications. I am not looking for proof of relativity, experimental or otherwise. I merely wanted to analyse the twins paradox.
JesseM: you said: "The flaw in this argument is that the standard rules of time dilation only work in inertial frames, and the rocket twin does not stick to a single inertial frame". In my version of the twin paradox, I had both twins accelerating the same way. That leaves us then only the parts of the trip where each twin's speed is uniform to consider for comparison. I have yet to see a resolution of that scenario that doesn't use the conclusion as an assumption in the process. (I still believe that if I ask "Why is the sky blue?", "Because blue is the color of the sky" is not a complete and satisfactory answer. Circular reasoning is just not my thing... Shoot me!)
Read this. If you are still confused, ask me questions:
http://sheol.org/throopw/sr-ticks-n-bricks.html
They didn't accelerate in the same way though. One accelerated twice between the time they began to move apart and the time they reunited--first to turn around after having left the earth, then to match his speed to the Earth to wait there for the other twin to return. The second twin, who spent longer away from the earth, only accelerated once, to turn around (you don't have to have him accelerate again once he reaches earth, you can just have the two compare clocks at the moment they pass at constant velocity).
I like to think of the twin paradox in terms of the "paths through spacetime" explanation. If you draw two points on a piece of paper, and one straight-line path between them and another with a bend in it, then you will always find that the straight-line path is shorter. Similarly, if you draw a spacetime diagram for the twins (with just one spatial dimension and one time dimension for convenience), they are taking two different paths between two points in spacetime (the point where they leave each other and the point where they reunite), and the way the time elapsed on a path is calculated in relativity insures that a straight path through spacetime will always have a greater proper time than any non-straight path between the same two points. So while the duration of the acceleration is not really important, the fact that acceleration leads to a bend in a twin's path through spacetime insures that it will have a smaller proper time. In your example where both twins accelerate, it's as if I had drawn two non-straight paths between the same two points in space, one consisting of two straight line segments joined at an angle, and one consisting of three straight line segments joined at an angle. Here, which path is longer really depends on the shape of the paths. Similarly, in your example it also depends on the shape of the path--it would actually be possible for the twin who spends most of his time on Earth to nevertheless be younger when they reunite, if he had been traveling at a much greater velocity relative to the Earth during his trip away and back. But if you specify they were both traveling at the same speed relative to the Earth during their trip, he will always have aged more. Similary, if you specify that the three-line-segment path through space has one segment that is parallel to a straight line between the points (analogous to the section of the twin's path through spacetime spent at rest on earth), and the other two segments are at exactly the same angle relative to this straight path as the two segments of the second path (analogous to the fact that in your example both twins have the same velocity during the inbound and outbound legs of their trip), then the path with three segments will always be longer than the path with two segments. If my descriptions are unclear I could provide a diagram as well.
You're equivocating on what kind of question you're asking though. If your question is about the internal logic of why relativity predicts that one twin will be younger, then in answering it we will take for granted the rules of relativity, and explain why the rules lead to these predictions. But if you're asking for experimental evidence that the rules of relativity are actually the ones that are seen in the real world, that's a totally separate question, the answer would involve various pieces of evidence for these rules such as the increased decay time of fast-moving particles or the workings of the GPS satellite system. If you want experimental evidence, than don't ask theoretical questions about the twin paradox, and if you want theoretical explanations of why relativity predicts one twin will be younger, then don't complain about "circular reasoning" when we assume the laws of relativity in our answer. Either one is inconsistent and illogical on your part.
Since this thread is still going, I have another question.
I personally don't like the Twins Paradox explanation with instantaneous turnaround. Or the two ship explanation where the incoming ship passes the outgoing ship at the distant star system. Considering this as two independent frames illustrates the math of time dilation, but, observers in the two ship frames will disagree with each other about the moment of departure from Earth and the moment of arrival back to earth. For example, with the two different ships passing each other in opposite directions at the star system 10 light years from Earth (earth frame), v = 0.866c, from Earth's frame the incoming ship arrived 23.1 years after the outgoing ship left. If you add up the times for the one way trip of each ship, we get 11.55 years. But, if we assume that Earth sends out a signal when the outgoing ship leaves earth, and the incoming ship received this signal, the incoming ship will calculate that he reaches Earth 46.2 years after the outgoing ship left earth. And similarly, if Earth sends out a signal when the incoming ship arrives at earth, and the outgoing ship eventually receives it, an observer on the outgoing ship will calculate that the incoming ship arrived at Earth 46.2 years after he left Earth (I hope I got this math right).
So, from the point of view of either ship frame, although it only took 5.77 years for them to get from Earth to the star system or vice versa, the total proper time (for either ship frame) between the event of the outgoing ship leaving Earth and the event of the incoming ship arriving at Earth is 46.2 years. Is this correct?
And this explanation also sidesteps some of the questions that arise from the Twins Paradox. With real acceleration involved, when the ship arrives at the star system, it will decelerate and at some point be at rest (at least momentarily) relative to the star system. And then will the distance between Earth and the star system "stretch back out" (as observed by the ship)? Does the ship observer observe Earth to "move" 5 light years farther away in a short period of time (v>c)? And then get 5 light years closer during the brief acceleration when the ship leaves the star system?
Is there a good explanation of the Twins Paradox available on the internet that addresses these kinds of questions?
I would like to find a good, comprehensive explanation to read before I ask a lot more questions.
And I hope nobody interprets this as a challenge to SR. Of course SR is mainstream science, and we have plenty of experimental evidence. But obviously this specific thought experiment has never been tested, and won't be in the foreseeable future. So it has to be resolved deductively, while assuming SR to be correct. But it's explanations are different and vary even in accepted textbooks. Of course they assume SR to be correct, since they are supposed to be explanations of how SR resolves the Twins Paradox. But, as far as I can tell, there is not universal agreement by mainstream sources about the details of this issue. And some details are not addressed at all.
Thanks,
Alan
Thanks,
Alan
The twins paradox has not been tested per se but there are plenty of other practical situations that received theoretical and experimental attention. Since you want something that you can read off the net, the best that comes to mind is the SR AND GR corrections that need to be applied prior to the launch of the GPS satellites. There may be more but this one is one of the best. See here:
http://relativity.livingreviews.org/open?pubNo=lrr-2003-1&page=node5.html
The other one that comes to mind is the Haefele - Keating experiment .You'll need to look up their paper.
Yes. The key concept here is that of instantaneously co-moving inertial reference frames. During the time period (as measured by the ship's clock, say) that the ship is accelerating or decelerating, it is not stationary in any single inertial reference frame. Nevertheless, at any point in time according to the ship's clock, it is instantaneously stationary in an inertial reference frame which is moving along with the ship. At that point in (ship) time, the distance between the Earth and the star system is contracted according to the relative speed of that instantaneously co-moving inertial reference frame with respect to the inertial reference frame in which the Earth and star system are stationary.
Loosely speaking, we can say that the ship "passes through" a continuous series of instantaneously co-moving inertial reference frames, with infinitesimal relative velocities between each pair of successive frames.
Yes, but you shoudn't think of this as a "genuine" v > c. The Earth's apparent superluminal velocity comes about because the ship is not moving inertially. The v <= c restriction applies to velocities of objects observed in a single inertial reference frame. (There's probably a more precise way to state this, but I can't think of it off the top of my head.)
Ever hear the saying, "There's more than one way to skin a cat?" :biggrin:
Of course, one way to test the twin paradox is to travel to a distant planet [insert: and back] at speeds close to the speed of light... then compare wristwatches. However, with an accurate enough clock, you don't need to go that far or that fast. Consider the clocks described here http://www.newscientist.com/article.ns?id=dn7397 "The first atomic clocks could pin this down to an accuracy of 1 part in 10^10. Today's caesium clocks can measure time to an accuracy of 1 in 10^15, or 1 second in about 30 million years." You can figure out the order of magnitude of v that corresponds to a gamma of (say) 10^(-15). I would think that such an experiment is possible in the forseeable future.
In my opinion, a "standard, mainstream textbook", especially one written by a non-relativist, is generally not the best place to find a definitive statement about "resolving the twin paradox", together with the various issues that may be raised. Such a textbook's explanation is usually based (read as "limited") by what material has been presented thus far in that textbook.
The variety of explanations arise from the many symmetries of Minkowski spacetime (see #5 in https://www.physicsforums.com/showthread.php?t=118994 ). In my opinion, the best explanations are the ones that use the fewest number of those symmetries... because they focus on the key physical idea: the proper-time [arc-length in spacetime] between two events is longest for the inertial observer.
As I have often said on this topic,
here's one of my favorite papers on the clock paradox:
http://links.jstor.org/sici?sici=0002-9890(195901)66%3A1%3C1%3ATCPIRT%3E2.0.CO%3B2-L
"The Clock Paradox in Relativity Theory"
Alfred Schild
The American Mathematical Monthly, Vol. 66, No. 1. (Jan., 1959), pp.1-18.
This addresses many of the approaches that have been suggested.
Al68 said:
I personally don't like the Twins Paradox explanation with instantaneous turnaround. Or the two ship explanation where the incoming ship passes the outgoing ship at the distant star system. Considering this as two independent frames illustrates the math of time dilation, but...
But nothing,
I thought you were getting the Twins but from the above I can see your still in the weeds.
You cannot do the twins where one returns the start with just two reference frames,
the traveler cannot get back to the other twin without a third frame.
And again if you don’t like transferring people at infinite accelerations – use the third returning frame to hold a clock and camera to take a photo back to earth.
Just collect ALL the data from all three frames with each photo to analyze what has happened.
Be sure Earth collects photos that include the WHERE and WHEN of all three reference frames as can be seen locally at Earth in all three frames for every event. Including: Three photos taken at Earth when that location is simultaneous with the traveling twin reaching the star for each of the three frames – That means three different photos of three unique events that hold 18 different pieces of information about Where and When those three events took place at earth.
Then do the same for star, based on a) when the Twin leaves Earth and b) when the photo of the twin and the star is brought back to Earth by someone in that third frame. That will be 36 pieces of information.
All these photos can be collected in one place after the fact for your review by whatever accelerations or data transfer is OK by you.
The conclusions you draw from this mathematical exercise using SR rules will correlate to the same kind of results that are always seen in experiments that confirm SR.
Take your time don’t lose track of a frame or locations and distances in it.
I agree with this description of what happens if you measure the distance in a series of instantaneously co-moving inertial frames, but I think it's misleading terminology to say this is what will be "observed by the ship", period. The series of co-moving inertial frames do not together define a single well-behave non-inertial coordinate system for an accelerating observer, because the same event could happen simultaneously with more than one point on the observer's worldline. And when dealing with non-inertial coordinate systems, there is no reason to see one choice as more physical than another, so you could equally well invent a very different non-inertial coordinate system in which the accelerating observer is at rest but the distance at any given moment does not correspond to the distance in the instaneous inertial frame at that moment. I think the word "observed" should only be used without qualification when talking about inertial observers, where there is a single well-known convention for how to define the coordinate system that constitutes their "rest frame", while it shouldn't be used for non-inertial observers, at least not unless you define in advance what coordinate system they are using to make "observations", with it being understood that this choice of coordinate system is a somewhat arbitrary one.
There is a shortish summary of many of the varioius methods of addressing the twin paradox at
http://math.ucr.edu/home/baez/physics/Relativity/SR/TwinParadox/twin_paradox.html
including an addendum about "too many explanations", which has a lot of very useful diagrams.
There are two general subsets of the many approaches that are worth some attention.
The first approach considers only what the two space-ships actually see. By this I mean the signals that they actually receive from each other. This is the "doppler approach". See figure 2 in http://math.ucr.edu/home/baez/physics/Relativity/SR/TwinParadox/twin_vase.html for instance.
A second subset of explanations focuses on which events different obsevers think of as being "simultaneous".
The most basic thing one must understand with the later approach is that simultaneity is relative. One can actually draw "lines of simultaneity" on a space-time diagram that represent different observer's concepts of simultaneity.
As we have mentioned in another thread, the slope of a line of simultaneity for an inertial obsever is always c^2 / v, also written as c/[itex]\beta[/itex] where [itex]\beta[/itex]=v/c.It is probably better NOT to get too mired in the working out of "what events are simultaneous to other events according to which observer" but it seems that some people just can't help it.
See figures 3 and 4 in http://math.ucr.edu/home/baez/physics/Relativity/SR/TwinParadox/twin_vase.html
for diagrams which show the lines of simultaneity.
I don't get it. You change the way I formulated the question, just so you can say they didn't accelerate in the same way? To have them experience the exact same accelerations overall is precisely why I had the second one decelerate before re-joining the point of origin.
Let me illustrate:
1.@@@@@@DDDDDD-@-@-@-@-@-@DDDDDD////////////////////////
2.@@@@@@////////////DDDDDD-@-@-@-@-@-@////////////DDDDDD
Legend: @=accelerate, D=decelerate, /=one month.
Since deceleration is merely acceleration in the opposite direction and wee're disregarding accelerations, since they are equivalent overall, we only have to compare 24 months at "low speed" to the 2 segments of 12 months at "high speed". Relativity tells us that the one at low speed could actually be the one moving at high speed. None has a more legitimate claim than the other. To understand this, imagine that their point of origin is actually moving, without them realizing it. Their trip, that they imagined as in the above illustration, actually could look like this:
1.DDDDDD@@@@@@DDDDDD-@-@-@-@-@-@///////////////////////
2.DDDDDD////////////@@@@@@DDDDDD////////////-@-@-@-@-@-@
This illustration is just as legitimate as the first one for the purposes of determining speed in a relative context.
As for your other argument, I'll always complain about circular resoning, because circular reasoning is simply bad logic. It should always be possible to work out the theory using logic.
Al68 said: "Of course they assume SR to be correct, since they are supposed to be explanations of how SR resolves the Twins Paradox." SR creates the Twins Paradox. That's why it's a paradox.
clj4: I read that thing, but it was really late at night and I'm still confused. I'll give it another try.
Yes, read again.
My point is that as long as you're assuming instantaneous acceleration, accelerations at the start or end of each one's path (with the start being where they depart at a common time and place, the end being where they reunite at a common time and place) don't affect the length of the path in between those points, so they're irrelevant. And if the acceleration is brief but not instantaneous, the difference between accelerating right near an endpoint or not accelerating will be very small, it won't substantially change the answer to which twin is older when they reunite.
Did you read everything I wrote about the "paths through spacetime" way of thinking about the problem, and did you understand why, in your example, their two paths will be quite different, regardless of whether the second one accelerates when he reunites with his twin who's already at rest on earth? I'll try to render a diagram here if it helps:../\
./..\___
Here position is the vertical axis, and time is the horizontal axis (ignore the rows of dots, they're just there to keep everything spaced right since the forum automatically deletes multiple spaces in a row...if the diagram is unclear I can redraw it as a nicer-looking image file on request). The *'s are the endpoints of the path, the top path involves first moving away from Earth (the part of the path slanted like /), then moving back towards (the part of the path slanted like \), then resting on Earth while waiting for the other twin to return (the flat part of the path which looks like ___ ), while the bottom just involves moving away from the Earth (\) and returning (/)between the two endpoints. If you understand the diagram, it should be obvious that it doesn't matter if the twin on the bottom path accelerates to come to rest on Earth right as he is about to reach the endpoint or not, it will have no significant effect on the overall length of the path between the two endpoints, and that's all that's important.
You should review the meaning of the term "circular reasoning", because proving that there is no logical inconsistency in a theory using the axioms of the theory itself is definitely not circular reasoning. Of course this can't prove whether or not the theory is true in the real world, only whether it contains any internal inconsistencies.
Complete nonsense. There is not a single scientific theory that can be proven using only "logic" without any need for observation. Both Newtonian mechanics and relativity are internally consistent, for example, it is only experimental tests which can tell you which is actually true in the real world.
