Answer for the Given on Steam Power Plant
The discussion highlights a lack of clarity in the original question regarding a steam power plant problem, as the problem statement was not provided. Two files were mentioned, but they did not contain the necessary details for assistance. Participants emphasized the need for the question to be clearly stated and for the poster to include their attempted solutions. It was suggested to repost the question in the appropriate homework help section following the required template. The thread was subsequently locked due to these issues.
PrinceAgustin
Steam Power Plant Questions
I did not see much of a question there. Perhaps you could spell out what you are asking?
its on the attached file
Determine the answers for the given data
No, it's not. There are two attached files and both show "given" data for a problem. The problem isn't stated. Nor did you state your attempt at a solution, which we also require. Please re-post this question in the relevant homework help section and follow the template.
Thread locked.
Likes PrinceAgustin
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
