Vertical Height Between Two Climbers
  • Thread starter Thread starter Doug Desatnik
The discussion centers on a homework problem involving kinematics in two dimensions, specifically calculating the vertical height between two climbers when a first aid kit is thrown. The initial velocity of the kit is 6.93 m/s at a 66.5-degree angle, and it is caught with a vertical speed of zero. Doug initially calculates the height using the equation Y = (V_final^2 - V_initial^2) / (2A), arriving at a height of 2.45 meters. He later realizes the question asks for the maximum height of the projectile and seeks clarification on rearranging the equation Y = (V^2 - V_initial^2) / -2g for this purpose. The discussion highlights the importance of correctly interpreting the problem and applying the appropriate kinematic equations.
Doug Desatnik
Answer Verification...*Please*
Hi Everybody,
I am having a problem with a homework question and think that I have finally got it right this time! Can somebody verify my work on this problem and let me know if I did indeed do this problem correctly? If not then can anybody help point me in the right direction and get me back on track?
The HW deals with Kinematics in 2-Dimensions
THANK YOU!
- Doug
The Question
A rock climber throws a small first aid kit to another climber who is higher up the mountain. The initial velocity of the kit is 6.93 m/s at an angle of 66.5 degrees above the horizontal. At the instant when the kit is caught, it is traveling horizontally, so its vertical speed is zero. What is the vertical height between the two climbers?
My Set-Up of Variables
V_initial = 6.93 m/s
V_final - 0 m/s
A = 9.80 m/s^2
Y = ? (SOLVE FOR)
T = ?
My Equation & Work
V^2=V_initial^2+2AY --> Y = (V_final^2 - V_initial^2)/2A --> (0^2 - 6.93^2)/2(9.80) --> 48.02/19.6 --> 2.45m
I wanted to try this question using this LATEX code, so here it is:
My Variables
V{0} = 6.93 m/s
V = 0 m/s
a = 9.80 m/s^2
My Equation
V^2=V{o}^2+2aY
My Work
V^2=V{o}^2+2aY --> Y=V^2 - V{o}^2/2a --> Y=(0^2 - 6.93^2)/(2)(9.80) --> 2.45m
LATEX is really cool! It will surely take some time to get used to but this is really a nice function!
Ok, so after looking at this problem a bit differently, it is obvious that what the question is asking for is the max height of the projectile, right? In that case then the equation would be:
V^2=V{o}^2-2gy
V{o}=6.93 m/s
V=0 m/s
g=9.80 m/s^2
y=?
I guess then my question becomes a simply math (algebra) problem... How do I rearrange the equation above to solve for the height, Y?
Is it like so?
Y=(V^2-V{0}^2)/-2g
- Doug
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
