Modeling Heat Transfer from a Flame to a Copper Tube using ANSYS
In summary, the conversation discussed difficulties in modeling a simplified version of a Steady State Thermal problem involving the superficial temperature of a copper tube and heat transfer from a flame. Various attempts and tutorials were mentioned, but ultimately the heat transfer mechanism was changed to external forced convection due to difficulties with the radiation model.
Vincenzo
Can't model a simplfied version of my problem, it's a Steady State Thermal problem. I'm trying to get the superficial temperature of a copper tube and the heat transfer from a flame to the tube(this is a simplified version of the problem).
Now my problem started when I couldn't find a way to modelate a flame or a heat source like a flame, so I did a cruel approximation and made some calculations changing the flame for a cylindrical body with superficial temperature equal to the adiabatic flame temperature(1500K) and a emisivity of 1.
To start an ANSYS simulation, after the having the geometry and the mesh done, one must introduce the boundary conditions, these as far as I know are:
1) The 1500K(1227°C) over the cylindrical body.
2)The existence of radiation between the bodies, with an emisivity of 1(flame). The temperature of the air around the tubes should start as 20°C. a "correlation" (I'm assuming this si to tell ANSYS the surfaces from where to take the vision/form factor) set as surface to surface.
3) The starting temperature of the copper tube, this is 20°C.(emisivity of 0,6)
So I set these conditions and then to the solution I set a Temperature over the copper tube, thing is,
1) I can't find a way to show me a progression over time to reach the 1500 K, it sets it inmediatly.
2) The amount of heat flow (W) absorved is way diferent to the one I calculated.
Radiation Heat transfer Eq: Q'=ε*As*F*σ*(T14-T24)
Outside diameter of copper tube is 33,4 mm
Outside diameter of "flame" is 49,25 mm
Separation between centers of both cylinders: 46,7375
Form Factor:0,1937 (using crossed string method)
I try to guide me from this course without sucess.
https://confluence.cornell.edu/display/SIMULATION/ANSYS+-+Radiation+Between+Surfaces
Any help is welcomed.
To add a sadness factor, this is for my thesis, I'm trying to do a propossal of a desing of an special steam generator and I already did several calculations by hand, just need the pretty color pictures and the data sheet of ansys to support my model... Well I'm still missing the part where I evaporate the saturated water, this is just to heat the water, not to change it's phase. I will get that part done this week hopefully.
Thanks for the time!
Not an expert, in fact I've never used ANSYS, just read the tutorial you linked to.
I'm assuming you are using a geometry similar that in the tutorial, with a half-shell being the flame and the specimen extended downward out of the shell.
Here's another tutorial that may be of help: https://confluence.cornell.edu/display/SIMULATION/ANSYS+-+Thermal+Stresses+in+a+Bar
Just some obvious things to check:
  • Initial conditions (misplaced decimal?)
  • Mesh size
  • Static analysis vs Transient analysis (both needed, Static to set initial conditions, then Transient for time series results)
  • Step size adequate for the thermal mass involved
  • Geometry;
    • a misplaced decimal for size or mass
    • mechanical interference between the pieces (do they touch each other?)
Likes Vincenzo
Thanks for the reply Tom, but I drop the model and change the heat transfer mechanism becuase I couldn't solve the radiation model. I change it to external forced convection.
Likes Tom.G
Sounds much more like a flame!
1. What is ANSYS Radiation modeling?
ANSYS Radiation modeling is a simulation tool that allows scientists and engineers to analyze and predict how thermal radiation will interact with materials and structures. It uses computational fluid dynamics (CFD) and finite element analysis (FEA) techniques to simulate the transfer of heat energy through radiation.
2. What are the applications of ANSYS Radiation modeling?
ANSYS Radiation modeling has a wide range of applications in various industries, such as aerospace, automotive, energy, and electronics. It can be used to analyze the thermal performance of materials and components, evaluate the effects of radiation on structures, and optimize designs for better energy efficiency.
3. How does ANSYS Radiation modeling work?
ANSYS Radiation modeling uses numerical methods to solve the equations governing the transfer of heat energy through radiation. It takes into account factors such as surface properties, geometry, and temperature gradients to accurately predict the behavior of thermal radiation in a given system. The results can be visualized through 3D models and graphs.
4. What are the advantages of using ANSYS Radiation modeling?
ANSYS Radiation modeling offers several benefits, including the ability to accurately predict thermal behavior, optimize designs for better performance, and reduce the need for physical testing. It also allows for the analysis of complex systems and provides valuable insights for improving product efficiency and safety.
5. Can ANSYS Radiation modeling be used for real-world applications?
Yes, ANSYS Radiation modeling has been extensively used in real-world applications by various industries. It has been proven to be a reliable and effective tool for simulating thermal behavior and optimizing designs. Many companies use ANSYS Radiation modeling to improve the performance and safety of their products before bringing them to market.
  • Classical Physics
  • Mechanical Engineering
  • General Engineering
