- 13,394
- 4,064
1.This ain't no joke...I need your help...
2.I came across this
PROBLEM
Compute:
L=:\lim_{x\rightarrow \pi} \frac{e^{\sin x}-e^{\sin 2x}}{\sqrt[3]{\pi x^{2}}-\pi} (1)
,without using Antoine L'Hôspital's rule...
MY SOLUTION:
I used this identity:
A^{3}-B^{3}\equiv (A-B)(A^{2}+AB+B^{2})(2)
,plugged in these values:
A\rightarrow \sqrt[3]{\pi x^{2}} (3)
B\rightarrow \pi (4)
and ended up with:
(\sqrt[3]{\pi x^{2}})^{3}-\pi^{3}=(\sqrt[3]{\pi x^{2}}-\pi)[(\sqrt[3]{\pi x^{2}})^{2}+\pi\sqrt[3]{\pi x^{2}}+\pi^{2}] (5)
Defining the animal from the square paranthesis as:
V(x)=:(\sqrt[3]{\pi x^{2}})^{2}+\pi\sqrt[3]{\pi x^{2}}+\pi^{2} (6)
,and using (6),and the fact that:
(\sqrt[3]{\pi x^{2}})^{3}=\pi x^{2} (7)
,equation (5) becomes:
\pi x^{2}-\pi^{3}=(\sqrt[3]{\pi x^{2}}-\pi) V(x)(8)
From (8),u can immediately see that:
\sqrt[3]{\pi x^{2}}-\pi=\pi\frac{(x-\pi)(x+\pi)}{V(x)} (9)
,where i made use of the decomposition:
x^{2}-\pi^{2}=(x-\pi)(x+\pi) (10)
and the factoring of \pi.
Using (9),the original limit (denoted by me with "L") becomes:
L=\frac{1}{\pi} \lim_{x\rightarrow \pi} \frac{e^{\sin x}-e^{\sin 2x}}{(x-\pi)(x+\pi)} V(x) (11)
Let's analize the V(x) when x\rightarrow \pi.I'm sure u'll find a finite positive number (if I'm not mistaking (that would be smth,i checked 3 times
) is 3\pi^{2} ),anyway,it's relevant that it doesn't really affect the limit in what comes next (of course,the obvious factoring and change of variable);i'll denote it simply by "V",videlicet:
\lim_{x\rightarrow \pi} V(x)=V(\pi)=3\pi^{2}=:V(12)
Then using (12) and the famous identity:
\sin 2x\equiv 2\sin x \cos x (13)
and factoring a minus sign and the exp(onential) with the smaller argument,i get:
L=-\frac{V}{\pi}\lim_{x\rightarrow \pi} \frac{e^{\sin x}(e^{2\sin x\cos x-\sin x}-1)}{(x-\pi)(x+\pi)} (14)
Now comes the "tricky part".The substitution
x\rightarrow y+\pi (15)
,under which:
\lim_{x\rightarrow \pi}\rightarrow \lim_{y\rightarrow 0}(16)
\sin x\rightarrow \sin (y+\pi)=-\sin y (17)
\cos x\rightarrow \cos(y+\pi)=-\cos y (18)
and the denominator:
(x-\pi)(x+\pi)\rightarrow y(y+2\pi) (19)
Then,by using (15) passim (19),the limit becomes (now u see why i insisted to compute V(x) with "x" equal to \pi,because it would have been really messy with "y"
L=-\frac{V}{\pi} \lim_{y\rightarrow 0}\frac{e^{-\sin y}(e^{2\sin y\cos y+\sin y}-1)}{y(y+2\pi)}(20)
And i now i pull the rabbit out of the hat:
I multiply and divide under the limit with the factor appearing in the exponential in the round bracket:
L=-\frac{V}{\pi} \lim_{y\rightarrow 0}\frac{e^{-\sin y}[e^{\sin y (2\cos y+1)}-1]}{y(y+2\pi)}\cdot \frac{\sin y (2\cos y+1)}{\sin y (2\cos y+1)} (21)
and make use SYMULTANEOUSLY of the famous limit:
\lim_{y\rightarrow 0} \frac{\sin y}{y} =1 (22)
and of another trick:U know that if y\rightarrow 0 (under the limit,of course),then the whole product \sin y (2\cos y+1)
goes to zero as well,trick which allows me to make use of another famous limit
\lim_{y \rightarrow 0} \frac{e^{y}-1}{y} =\ln e=1 (23)
Then i swich numerators and denominators in (21) as to make use of the relations (22) and (23),to finally get the result
L=-\frac{V}{\pi} \frac{3}{2\pi} (24)
and then i make use of the relation (12) which gives me V,i finally obtain
L=-\frac{9}{2} (25)
Hopefully i didn't f*** up any calculations...
Daniel.
PROBLEM
Compute:
MY SOLUTION:
and ended up with:
,under which:
L=-\frac{9}{2} (25)
Daniel.
