Anybody help with these questions?
  • Thread starter Thread starter scw1
The discussion centers on calculating the maximum uniform internal pressure for a spherical pressure vessel designed to maintain tensile stresses below 150 MPa, with a radius-to-wall thickness ratio of 100. Participants clarify the correct formula for pressure, which is P = σt/r, and confirm the ratio is expressed as r/t = 100. There is some confusion regarding the initial pressure calculation, with one user suggesting 0.15 MPa and seeking validation. The conversation emphasizes the importance of using the correct equation and understanding the ratio notation. Accurate calculations are crucial for ensuring the vessel's structural integrity under pressure.
scw1
A spherical pressure vessel has been designed such that the tensile stresses in its walls should not exceed 150MPa. The ratio of the vessels radius to wall thickness is 100. Applying a thin-walled plane stress assumption, what is the maximum uniform internal pressure that the vessel is intended to contain?
Thin walled pressure cylinder assumption P= sigma(s) x radius/2xt(s)
i tried the answer 0.15MPa but not sure if its right can anyone help me??
Your equation should read σ= (Pr)/t or P = σt/r
Hi how do you denote the radius to wall thickness, is it 100 to 1 or 10 to 0.1?
Many thanks
Stevo
Many thanks
Stevo
since r is the radius and t is the wall thickness
radius to wall ratio = 100 OR r/t = 100.
Good advice by rock.freak667, except the equation should be sigma = p*r/(2*t).
Yes it should, I was thinking about a thin-walled cylinder.
