How can I solve this nonlinear ODE homework on Apollo reentry?
Mr.Waka
http://www.math.udel.edu/~moulton/Apollo%20EC.pdf
This is the full problem that I am working on for my ODE class.
I would figure acceleration equals the second derivative so a=d^2s/dt^2
and V=ds/dt like the hint says.
I looked over the examples of Nonlinear ODEs but they all have 2 variables instead of just one like this one. I was looking for an integrating factor but none of that works out I think. I tried to integrate it by parts twice but that lead to a jumbled mess. I tried to subsitute s in terms of V but that didnt work to well either.
For me the only trouble that I am having is the fact that its a nonlinear problem with really only one variable because V is in terms of S
And looking at a,b and c all of them don't deal with the s variable. I'm not too sure where in the math that it gets canceled out. In fact each step seems to reduce the variables needed.
Im just not sure how to tackle the problem. The math shouldn't be bad but I can't find a place to start.
A common trick you can use is that dv/ds = (dv/dt)*(dt/ds) = (dv/dt)*1/v = d^2 s/dt^2 * 1/v. Since d^2 s/dt^2 is given in terms of v and s, you get a differential equation for dv/ds which you can solve easily by separating. After solving for v you plug that in the original equation to get an equation for a in terms of s. Then you can find the maximum of a by finding what a is when a'(s) = 0. When I did this, the answer I got for part a) was off from what they got by a factor of 1/2, however I got the same thing they did for part b)...
