Apparent magnitude of the Moon from Mercury?
The discussion centers around calculating the apparent magnitude of the Moon as observed from Mercury, assuming Mercury is at a distance of 0.52 AU from the Moon during a full moon. Participants explore the necessary equations and concepts related to apparent and absolute magnitudes, as well as the distances involved.
  • Homework-related
  • One participant presents the equation M = m + 5 - 5log(d) but expresses confusion about the absolute magnitude (M) of the Moon, noting that they only have the apparent magnitude from Earth.
  • Another participant suggests simplifying the problem by skipping the absolute magnitude at 10 pc and instead focusing on the distance of the Moon from Earth in AU to find a ratio of distances.
  • A participant acknowledges their lack of familiarity with the necessary ratios and equations, expressing confusion about how to proceed with the homework assignment.
  • Another participant critiques the previous equation used by the homework participant, pointing out that it lacks the necessary luminosity term for the Moon and emphasizes the importance of considering the inverse square law for brightness based on distance.
  • A further elaboration on the relationship between luminosity and distance is provided, suggesting a logarithmic approach to relate the apparent magnitudes based on their distances.
Participants do not reach a consensus on the best approach to solve the problem, with multiple competing views on how to utilize the equations and concepts related to apparent magnitude and distance ratios.
Participants express uncertainty regarding the absolute magnitude of the Moon and the appropriate equations to use, indicating a reliance on potentially incomplete or unclear instructional materials.
rtfirefly
I know there there has to be a simple answer to this, but I can't understand where it's at. Here is the question.
Find the apparent magnitude of the Moon [Earth's] as seen from Mercury. Assume Mercury is 0.52 AU from the Moon and that Mercury sees the Moon fully [it's a full moon].
Okay, here is where my thinking lays. I'm going to be using M = m + 5 - 5log(d), where M = absolute magnitude of the Moon, m = apparent magnitude of Moon, and d = distance from Moon to Mercury in parsecs = 2.521×10^(-5) pc.
But the problem I run into is M - I don't know it. I know that the absolute magnitude is the apparent magnitude measured at 10pc, but then I run into not knowing m. I guess I could use the apparent magnitude from Earth (≈-12.6), but when I plug that into the equation using the 10pc I get back -12.6 for the absolute magnitude and that does not work for me. I can only presume I am missing a piece of the puzzle and I don't know where it is. Any help you can offer me would be appreciated.
Astronomy news on Phys.org
Simplify it: skip the 10 pc.
The piece of puzzle which you have not mentioned is the distance of Moon from Earth. Since the distance of Mercury from Moon is conveniently in AU, which is of convenient magnitude, find out distance of full Moon from Earth in AU.
Then ratio of distances Moon-Earth and Moon-Mercury. Which you can then get logaritm from.
Right, thank you, but I was only given this one ready assignment that sort of talks about this stuff and the homework is based on it and did not read anything about this. The closest that it talks about ratios is be using the equation: m -n = 2.5log(Ln/Ln), where m and n are two apparent magnitudes, and Ln and Lm are their brightness. So I really don't know what equation I should be using to solve this problem. I realize that I may have to think outside the text (though in my experience teachers don't like you coming up with stuff from other places), but I did anyways and I still am confused as too what I am suppose to do. I think I'm thinking to hard now and everything at this point is becoming muddled.
You have (Ln/Ln) in your equation - no Lm, and twice Ln, so that expression is always 1.
Just consider that the apparent luminosity decreases with inverse square of distance - for the same source like full Moon and viewed from the same direction,
Lm*dm2=Ln*dn2,
where dm is the distance where object has brightness Lm, and dn is distance where the object has brightness Ln.
Divide that expression with
Ln*dm2
and we get
(Lm/Ln)=dn2/dm2
Now take the logarithm
log (Lm/Ln)=log((dn/dm)2)=2log(dn/dm)
so
2,5 log(Lm/Ln)=5log(dn/dm)
Can you continue from that point?
  • · Replies 33 ·
