Apparent Magnitude: Understanding Star X's Brightness
The apparent magnitude of a star, denoted as "m," refers to how bright it appears from Earth, defined relatively to a reference point, historically set at Vega with a magnitude of 0.0. The equation m_2 - m_1 = -2.5 log (B_2/B_1) allows for calculating differences in apparent magnitudes based on brightness ratios. While the sun is the brightest object in the sky, its absolute magnitude indicates it would appear dim if viewed from a distance of 10 parsecs, illustrating the distinction between apparent and absolute magnitudes. Factors like atmospheric filtering and the observer's eye sensitivity can affect brightness measurements, necessitating clear specifications of wavelengths used in observations. Understanding these concepts is crucial for accurately interpreting star brightness and its implications in astronomy.
devd
What does this statement mean: "Apparent magnitude of a star, X, is m." ?
Apparent magnitudes are defined relatively, right? We can talk about differences in apparent magnitudes. If i know the ratio of the brightnesses, i can find out the difference in apparent magnitudes. Do we have some kind of reference magnitude, relative to which we can make the statement in quotes?
Astronomy news on Phys.org
I can understand that qualitatively. But, what about the quantitative statement?
Your quantitative expression is correct, and it is true that you need some reference to set the scale. Historically the star Vega was assigned an apparent magnitude of 0.0 to set the zero point of the scale. However, today the reference is defined as a certain flux in ergs/s/cm^2/Hz, as shown in the table in the Wikipedia entry. Vega is still quite close to an apparent magnitude of 0.0 with this definition.
jedishrfu's statement is incorrect. Apparent magnitude describes how bright an object appears. No celestial object has an apparent magnitude brighter than the sun (obviously). I think what jedishrfu was trying to say refers to absolute magnitude, which describes the intrinsic brightness of an object. Absolute magnitude is defined as the apparent magnitude of the object when viewed at a distance of 10 parsecs. The sun has an apparent magnitude of about -27, but an absolute magnitude of +4.83, so it would be a dim naked eye star if it were 10 parsecs away. While it is true that most naked-eye stars are intrinsically brighter than the sun (meaning they have an absolute magnitude less than the sun), it is not true that all naked eye stars are intrinsically brighter than the sun. Epsilon Eridani, for example, is a nearby naked eye star with an apparent magnitude of +3.7 but an absolute magnitude of +6.19, meaning that it is intrinsically fainter than the sun
Likes 1 person
Its one of the many ironies of Science that the thing that is easy to measure (brightness) is not considered absolute, and that absolute magnitude is a calculated (adjusted) value which requires several estimated parameters to determine (even apparent magnitude does). I expect I'm not telling you anything if I rearrange your equation to:
m' = m-2.5*log(B'/B) [where m'=m_sub2, B'=B_sub2, m=m_sub1, etc.] which answers your question (as long as we agree what (star) to use for m and B (as well as units and measurement). No particularily good reason that brightness should arbitrarily use the visible spectrum, other than that's what we see. Why its adjusted to remove atmospheric filtering is another question. Between any star and us is the following filters: dust and gas and plasma, the atmosphere of the Earth, the optical properties of the telescope, the optical clarity of our eyes, the sensitivity of your eye to different wavelengths (there are as many 'average' observers as there are 'average families'(with 2.1 children)). Its a very good idea to specify a (range of) wavelengths (as well as how the cut-off at each end is handled), but its not been that long since we first figured out how to measure the flux at a given wavelength with high accuracy. Early photodetectors were notoriously inefficient at capturing photons.
Likes 1 person
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
