What value of theta maximizes the area of a triangle with sides a and b?
cheezeitz
Two sides of a triangle have lengths a and b, and the angle between them is theta. What value of theta will maximize the triangle's area? (Hint: A=1/2absin(theta)
I have a triangle drawn, with the base being a, and the height being b. From the equation given, does the value of b actually equal theta times the angle?
I'm trying to relate the two angles so i can solve for one variable, but not sure where to start.
Ok, well it seems like you are trying to say one leg of the triangle is the height. But look at the hint. A=1/2 b*h if you anchor one leg on an axis, then let the other leg move
You have a base b, and the h=asin(theta) Anyway, if you take dA/dtheta that's how the area changes as theta changes. So basically just take the derivative of that area function with respect to theta. When that function equals 0, you have a maximum area.
I tried it out, and you end up with 1/2(absin(theta)) a and b are constant so dA/dtheta = 1/2(abcos(theta) Set that equal to 0. divide out the constants, you have cos(theta) = 0
This gives you an angle of pi, which would be a right triangle, which makes sense to me. Shouldn't the right triangle have the greatest area?
Hope that makes sense.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
