Which of these two decays is more likely using the CKM matrix?
InsertName
I'm trying to get familiar with how to use the CKM matrix when tackling such questions as "which of these two decays is more likely".
My example question is:
Which is more likely c\bar{d} ---> s\bar{d} or c\bar{d} ---> d\bar{d}
The relationship between the weak eigenstates, the CKM matrix and the mass eigenstates:
(\acute{d}) (Vud Vus Vub) (d)
(\acute{s}) = (Vcd Vcs Vcb) (s)
(\acute{t}) (Vtd Vts Vtb) (t)
I don't actually know where to start because I'm not sure how to use the CKM matrix in this way.
Here's my best guess:
The difference between the two interactions is that one has c--->s and the other has c--->d and the value of the element Vcd < Vcs so the most likely is c--->s so the most likely decay is c\bar{d} ---> s\bar{d}.
Any help with this is much appreciated.
Just add absolute values to your inequality (since the entries in the CKM matrix are generally complex), and you should be fine.
Cool, thanks.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
