Solving Three Force Motion Problem: Find Third Force
  • Thread starter Thread starter Huskies213
    Force Motion
To solve the three-force motion problem, it is established that the object moves with constant velocity, indicating that the net force is zero. The first force is 6.5 N in the positive x-direction, and the second is 3.5 N in the negative y-direction. The third force must counteract these, having a negative x-component equal to -6.5 N and a positive y-component equal to 3.5 N. The magnitude of the third force is calculated as 7.38 N, and its direction can be determined using inverse trigonometric functions based on the components. Understanding the relationship between the components and the resultant force is crucial for finding the angle and ensuring the forces balance correctly.
Huskies213
Can anyone help with what formulas to apply/use here ?
An object acted on by three forces moves with constant velocity. One force acting on the object is in the positive x direction and has a magnitude of 6.5 N; a second force has a magnitude of 3.5 N and points in the negative y direction. Find the direction ° (counterclockwise from theC +x axis) and magnitude (N) of the third force acting on the object.
The fact that the object moves with 'constant' velocity means that it is not accelerating, which would imply a change in velocity. The fact that it is not accelerating indicates that the net force or sum of forces is nil (0).
Therefore the third force must have a component equal to but opposite of the force in the +ve x-direction, and a y component which is equal to but oppositve the force in the -ve y-direction.
Then the angle is simply determined by an inverse trig function based on ratio of either the x or y component for the third force and the total or resultant force.
Re
i got the answer of 7.38 for the first part (which is correct) but I'm still unsure about the second part. can anyone help ?
The vector is in the upper left quadrant (of the Cartesian coordinate system) since its x-component must be - to offset the + x-force, and its y-component must be + to offset the - y-force.
7.38 is correct! This should simply be \sqrt{3.5^2\,+\,6.2^2}.
Think of a vector F which has two components, Fx and Fy, and both components are orthogonal.
The magnitude of F = \sqrt{(F_x^2\,+\,F_y^2)}, and Fx = F cos\theta and Fy = F sin\theta, where \theta is the angle between F and the x-axis.
Think of the definition of the cos of an angle and how it relates to the legs and hypotenuse of a right triangle.
