Applying Mech Enginneering for an Independent Project
A high school senior is seeking advice on a mechanical engineering project to undertake over the summer, aiming to apply and enhance their skills. They are currently self-studying physics and taking calculus BC in preparation for the AP exam. A suggestion was made to design and build a robotic unicycle, emphasizing the learning experience rather than the practicality of the project. The community encourages further questions and offers support for any technical challenges encountered during the project. Engaging with experienced members can provide valuable insights and assistance throughout the process.
alexjc103
Hello,
I am a senior in high school as of Fall 2012 and I am new to PF. Currently I'm self studying physics in preparation for the AP exam( I am aiming for C Mech, if i am prepared in time)and am taking calculus BC. My goal is to take up a project over the summer in which i could apply mechanical engineering skills, where i could get an insight into mechanical engineering while i learn the skills necessary to complete the project. I'm having trouble deciding upon a project and my search is the reason I have come across PF. Could you please give me an example of such a project that is challenging yet manageable by someone just entering the world of mechanical engineering. Your response would be much appreciated.
alexjc103, Welcome to Physics Forums!
How about designing and building a robotic (remote control) unicycle? Not that the item itself would be useful, but researching, designing, and building all the technology necessary would be the value.
Thanks Bobbywhy, your answer is much appreciated. I now have to research and get started on my project.
If you encounter doubts, conflicting information, or technical questions, then come right back here and ask away. Here there are members with high levels of education, or experience, and both. All are ready to assist you. Let us know what project you decide on.
Cheers,
Bobbywhy
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
