Area between a function and its tangent
Momentum09
Find the area of the region bounded by the graph of f(x) = 4x^2, the tangent line to this graph at P(2, f(2)), and the x-axis
Integral of [f(x)-g(x) dx]
I first tried to find the equation for the tangent line
The derivative of 4x^2 = 8x, subsituting x=2 into the equation I got 16 [slope]
the equation then turned out to be y-2 = 16 (x-2) --> y = 16x-30
I then subtracted this tangent equation from 4x^2 then integrate, but I wasn't able to get the right answer.
Please show me how...thank you!
Why did you have y - 2 = 16(x - 2)? If I plug in x = 2 I think it is not a tangent line...
Hi Momentum09! :smile:
I'll just add to what CompuChip :smile: says …
why not just integrate under the parabola in the usual way, and then subtract the area of the triangle using half-base-times-height? :wink:
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
