Area of the region inside the unit circle
The problem involves finding the area of the region inside the unit circle and above the graph of the function f(x) = x^5. The context is set within the subject area of calculus, specifically focusing on integration and area between curves.
  • The original poster attempts to identify integration points for calculating the area but questions the appropriateness of their chosen limits. Some participants question the integration points and suggest considering the properties of the unit circle and the intersections with the function.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some guidance has been offered regarding the points of intersection and the nature of the curves involved, but no consensus has been reached on the correct approach or integration limits.
There is a mention of the difficulty in finding the points of intersection, as it leads to a complex equation. The original poster expresses uncertainty about the ability to integrate with respect to y due to perceived limitations.
aznboi855
The area in the region inside the unit circle and above the graph of f(x) = x^5
I don't know how to type the equation in here but the area is the integral between two integration points of the higher curve minus the lower curve.
I tried using the integration points 0 and 2.02381 (the farthest the graph will stretch out according to derive), but that's the area outside and under the curve, i think the question is asking for the area INSIDE the curve.
As far as I know you can't do it with respect to y because it's infinite.
Thanks.
I'm not sure why you'd be using those integration points. For a unit circle, what is the largest possible value of x and/or y? Or, maybe think about the equation for a unit circle. Where does f(x) cross the unit circle?
(1,1)? So it'll be from 0 to 1 correct?
If we were to do it that way, the point of intersection would be 1 and I'm guessing the radius will be on top of the curve?
So it'll be... SQRT(1-x^2) - (x^5)?
(1, 1) is not a point on the circle.
Finding the points of intersection entails solving the equation sqrt(1 - x^2) = x^5. If you square both sides, you get a 10th degree equation that has no easy-to-get solutions.
