Assistance with Vertical Terminal Velocity motion - What do you think?
A parachutist falls at a constant speed of 12 m/s and drops a coin from 50 meters above the ground. The final velocity of the coin upon impact is calculated to be 33.53 m/s, and it takes approximately 2.19 seconds for the coin to reach the ground. The parachutist, traveling at constant velocity, takes about 4.16 seconds to reach the ground. The time difference between the coin and the parachutist hitting the ground is determined to be around 2 seconds. The discussion emphasizes using the correct equations for constant velocity and acceleration to solve the problem accurately.
TheKovac
A parachutist is falling vertically with a uniform speed of 12 m/s. At the instant he is 50m above the ground, he drops a coin. (Ignore Air Resistance)
A) What is the seed with which the coin strikes the ground?
b) How long does it take for the coin to reach the ground
C) WHAT IS THE TIME DIFFERENCE BETWEEN THE COIN AND PARACHUTIST REACHING THE GROUND?
v^2 = u^@ + 2ax
x=Ut+0.5at^2
x=0.5(u+v)t
v=u+at
a)
=> v^2 = 12^2 +2(9.8)(50)
final velocity of coin= 33.53m/s RIGHT
b)
x=ut + 0.5at^2
50= 12t +0.5(9.8)t^2
4.9t^2 +12t -50=0
time for coin to reach ground = 2.19s
c) =?
Is this question able to be solved, with the current data, because I believe I would need mass or total displacement to correctly work the answer.
Can someone please help me on how to go about answering such a question as this.
Kindest Regards,
TheKovac
HINT: The parachutist is traveling at constant velocity.
My goodness, could be as simple as:
t= x/a
=> t= 50/9.8
Which would result in:
t= 4.16s
=> t(coin)= 2.16s
=> t(parachute) = 4.16s
t(difference) = 2s
Is that how simple the answer is?
Your close, but be careful. What is the definition of velocity?
Velocity = Vector quantity of the rate of change of displacement.
So I am missing direction? Thats it?
Not quite, speed is defined as the magnitude of velocity, or the rate of change of distance with time,
|v| = \frac{dx}{dt}
not
|v| \neq \frac{da}{dt}
as you had. In this case the acceleration is zero.
So with that in mind, is this how to work the difference?
If the velocity is constant, then can we use t = x/v ?
t(parachutist)= 50/12
t(parachutisit)= 4.16
t(coin) = 2.16s
t(difference) = 2s
I think this one is right?
I worked out that my problem above, is that I used the equation for acceleration, when Acceleration was Zero, instead I should have used the equation for velocity, right?
t(coin) = 2.16s
t(difference) = 2s
I've not checked your arithmetic, but your method is correct, as it is for all the previous questions :approve:
