Astronaut shoots a bullet into the sun - gravity assists?
In summary, an astronaut shooting a bullet into the sun is a concept that has been considered for potential gravity assists in space travel. The idea is that the bullet's trajectory would be affected by the sun's massive gravitational pull, propelling it to reach incredible speeds and possibly assist in a spacecraft's journey. However, this theory has not been tested or proven, and it remains a hypothetical concept in the world of space exploration.
rcgldr
Homework Helper
8,855
632
This question came up at another forum. The delta-v of potential guns is limited to the range 3 km/s to 11 km/s (hydrogen gun). Assume the astronaut is either on the moon or orbiting the moon. I'm wondering if a single impulse followed by gravity assists (and ideal planet alignment) could result in the bullet's orbit intercepting the sun.
Would 3 km/s to 11 km/s be sufficient to achieve a gravity assist with Mars (assuming it's located in an ideal part of it's orbit)? If not, the next option would be a gravity assist from Earth and then one or more planets to achieve a Sun intercepting orbit?
I am sure it's possible in principle to launch a small projectile that eventually collides with the Sun.
It could take a a while to get there though, and how could this be a useful project?
As in "This is left as an exercise for the reader." Or to put a 'forbidden here', philosophical bent on it; "Is information that is not immediately used useful?" Or perhaps as a variation on a Hohmann transfer orbit. Or is it useful to have enough gasoline in your parked car to get to a refill station while you are in bed asleep?
The escape velocity from Earth at the average radius of the moon's orbit is about 1.438 km/s. The moons average orbital speed is about 1.022 km/s. Escape velocity from the surface of the moon is about 2.38 km/s, so a bullet speed of 3 km/s from the surface of the moon in the right direction should be enough to achieve escape velocity from Earth and moon system. That in itself doesn't mean it would end up in an orbit that intercepts the sun, but perhaps enough to get a gravity assist from another planet that would do the trick.
The question was posted at stack exchange in reference to a comic strip.
https://space.stackexchange.com/questions/26276/could-an-astronaut-safely-shoot-the-sun-with-a-gun
I'm not sure of the point of the comic strip was, but the answers posted there didn't seem to consider gravity assist. A somewhat recent example of gravity assist was the 12 year path of Rosetta:
or the 5 man made objects that have left the Solar System.
https://en.wikipedia.org/wiki/List_of_artificial_objects_leaving_the_Solar_System
Voyager 1:
Why not Venus?
Think of this as a problem of shedding velocity. It's presently going too fast to hit the sun.
Vanadium 50 said:
Why not Venus?
I forgot to include Venus as well as Mars as the two closest planets to use gravity assist to change the path of the orbit. I'm wondering if the thin atmosphere of Mars would allow for a closer flyby. My idea on this was to increase the eccentricity of the orbit more that slow down the speed relative to the Sun.
The Rosetta gravity assist was interesting in that it involved both the sun and the earth. The launch of the Rosetta put it into a solar orbit that intercepted the Earth one year later, resulting in enough gravity assist for it to reach Mars.
So one achieve a hyperbolic orbit of the bullet relative to the earth-moon system, but not all that much to deduct from the Earth's speed revolving around the sun.
One thing to be looked at is the eccentricity of the bullet orbit wrt the sun and whether an intercept with a Martian or Venetian orbit is possible.
256bits said:
So one achieve a hyperbolic orbit of the bullet relative to the earth-moon system, but not all that much to deduct from the Earth's speed revolving around the sun. One thing to be looked at is the eccentricity of the bullet orbit wrt the sun and whether an intercept with a Martian or Venetian orbit is possible.
The goal here is more about increasing eccentricity to intercept the sun as opposed to reducing speed. Looks like setting up an orbit (relative to both Earth and sun) that re-intercepts the Earth about a year later can provide a fairly large gravity assist to increase eccentricity. Rosetta used this method to intercept the Earth a year after launch which allowed it to reach and get a gravity assist from Mars (the timing with Mars orbit had to be setup for this to work).
@rcgldr Oh. OK. I didn't read post #6 like a should have. You already took all that into account.
In principle it is possible, but Venus or Mars won't help. You have to reduce the speed in the tangential direction to nearly zero to fall into the Sun, this corresponds to 35 km/s relative velocity for Venus, 30 km/s for Earth and 24 km/s for Mars. All these speeds are much larger than the escape velocity - to achieve them in a fly-by, you have to start with a high retrograde speed (as seen from the planets) already. A single fly-by won't make it and multiple fly-bys are impractical as well.
What you would need is a fly-by at Jupiter. A few kilometer per second are sufficient to reach Jupiter, and a single fly-by can reduce the tangential speed to nearly zero. Without course corrections your chance to hit the right spot at the Jupiter fly-by is small, but you can shoot many bullets to increase the chance...
1. How does gravity assist work?
Gravity assist, also known as a slingshot effect, is a technique used by spacecraft to gain speed and alter their trajectory by using the gravitational pull of a planet or other celestial body. The spacecraft approaches the planet at a specific angle and uses its gravity to accelerate, which in turn reduces the planet's orbital velocity. This results in the spacecraft gaining speed and being flung in a different direction.
2. Why does the astronaut shoot a bullet into the sun instead of just launching it?
Launching a bullet directly into the sun would require a large amount of fuel and energy, making it an impractical and expensive method. By using a gravity assist, the spacecraft can conserve fuel and use the sun's gravitational pull to gain speed and change its trajectory towards the desired destination.
3. How does the bullet not burn up in the sun's extreme heat?
The bullet is not actually being shot into the sun's surface, but rather into its gravitational field. The gravitational pull of the sun is what affects the bullet's trajectory, not the intense heat of the sun's surface. Therefore, the bullet will not be affected by the sun's heat.
4. What is the purpose of shooting a bullet into the sun using a gravity assist?
The purpose of this technique is to conserve fuel and energy while still being able to reach faraway destinations. By using a gravity assist, the spacecraft can gain enough speed and change its trajectory to reach distant planets or other celestial bodies without expending a significant amount of fuel.
5. How do scientists calculate the trajectory of the bullet after it is shot into the sun using a gravity assist?
Scientists use complex mathematical equations and computer simulations to calculate the trajectory of the bullet after it is shot into the sun. They take into account various factors such as the mass and velocity of the bullet, the gravitational pull of the sun, and the angle at which the bullet is launched to accurately predict its path.
  • Aerospace Engineering
  • Astronomy and Astrophysics
