At Which Value of x is the Magnetic Field Zero?
  • Thread starter Thread starter K3nt70
    Magnetic Wires
The magnetic field between two parallel conducting wires is zero at a specific point on the x-axis. Wire 1, located at x = -1.80 cm, carries a current of 2.60 A out of the xy-plane, while Wire 2, at x = 1.80 cm, carries a current of 8.80 A into the xy-plane. The correct position where the magnetic field is zero is calculated to be at x = -3.3096 cm. This conclusion is confirmed by applying the formula B = μI/(2πr) and solving for the distance between the wires.
  • Understanding of magnetic fields generated by currents
  • Familiarity with the Biot-Savart Law
  • Proficiency in algebraic manipulation and solving equations
  • Knowledge of the right-hand rule for current direction
  • Study the Biot-Savart Law for calculating magnetic fields
  • Learn about the superposition principle in electromagnetism
  • Explore the effects of varying current on magnetic field strength
  • Investigate applications of magnetic fields in engineering contexts
Students in physics, electrical engineers, and anyone studying electromagnetism or conducting wire interactions.
K3nt70
Consider two parallel conducting wires along the direction of the z axis as shown below. Wire 1 crosses the x-axis at x = -1.80 cm and carries a current of 2.60 A out of the xy-plane of the page. Wire 2 (right) crosses the x-axis at x = 1.80 cm and carries a current of 8.80 A into the xy plane.
At which value of x is the magnetic field zero? (Hint: Careful with sign)
http://img234.imageshack.us/img234/6758/14937203wx9.png
[tex]B = \frac{ \mu I}{2 \pi r}[/tex]
Since i know that the point I am looking for will be to the left of -1.80 cm on the x-axis, i should be able to deduce a distance from that point using:
[tex]\frac{2.6}{d} = \frac{8.8}{d + 3.6}[/tex]
I found d to be 4.2871. I added this to 1.8 meaning the point it at -6.09 cm on the x axis, which is incorrect. Is my math wrong?
edit: actially, i found d to be 1.50967 and the point on the x-axis to be -3.3096 cm. This makes sense, but I am kind of afraid to try it since i only have one more attempt at the problem. Any confirmations?
nevermind. I checked my answers with the formual for magnetic field, and it was correct.
  • · Replies 21 ·
