Atoms Unite: Gas vs. Non-Gas Molecules
Substances like nitrogen and oxygen exist as diatomic molecules (N2 and O2) in their gaseous forms due to the instability of monoatomic species. Monoatomic nitrogen (N) and oxygen (O) are not stable because they need to fill their valence electron shells to achieve a noble gas configuration. This stability is achieved by forming bonds with other atoms, resulting in diatomic molecules. For example, sodium is rarely found as a monoatomic ion (Na+) because it is highly reactive and seeks to bond with other elements, such as in sodium chloride (NaCl). The discussion emphasizes the importance of electron configuration in determining the state and stability of elements.
scientifico
Hello, why much substances have one atom when aren't gas and 2 same atom united when are gas (for example N and N2, O and O2) ?
Thanks!
Chemistry news on Phys.org
I don't quite understand what you are saying.
I mean why for example the gaseous nitrogen molecule became N2 instead of just remain N and separe from the other molecules?
Monoatomic species such as O or N are not stable and require filling their valence shells to achieve noble gas configuration. They fill these outer energy levels by forming bonds with elements that can afford to give up or share electrons.
Its the same reason why you encounter sodium as a salt (NaCl) and hardly every by itself. Sodium is highly reactive because mono-atomic sodium (Na+) is electron deficient and will violently react with water in a highly exothermic reaction.
http://www2.uni-siegen.de/~pci/versuche/english/v44-1-1.html"
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
