Attraction of -Q to +Q in x and y directions
  • Thread starter Thread starter Violagirl
    Attraction
The discussion focuses on calculating the force on a charge -Q influenced by two other charges, Q1 and Q2, in both x and y directions. The user has derived expressions for the forces in each direction, using the formula F = k(q)(Q)/r². They are questioning the correctness of their calculations and the direction of the resultant force. Clarifications are provided regarding the direction of the forces, noting that the negative charge -Q will indeed be pushed in the negative x direction. The conversation emphasizes the importance of correctly identifying the vector components and their respective directions in force calculations.
Violagirl
Find the magnitude and direction of the force on the charge -Q on the figure in the attached document.
F = k(q)(Q)/r2r-hat
So I have a force in the x direction and a force in the y direction.
Fx = k(Q1)(-Q)/(a) x-hat
Fy = (k)(Q2)(-Q)/(a) y-hat
F = Fx + Fy = -kQ22/(a)2 x-hat + -kQ12/a2 y-hat
Is this right? Or can more be done to solve it?
Almost there - check the directions of the forces.
Your formula has the -Q charge being pushed in the -x direction.
Is that what would happen?
In general - the force experienced by charge q due to charge Q is:
$$\vec{F}=\frac{kQ}{r^3}q\vec{r}$$ Here r points from Q to q.
