Atwood System - max. height of the lighter object
The discussion revolves around an Atwood system involving two masses, where the lighter mass's maximum height after release is being analyzed. The original poster has calculated the acceleration of the system and the velocity of the lighter mass when the heavier mass hits the ground, but is uncertain about the next steps and the concept of "launch speed."
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the calculation of acceleration and velocity, with the original poster questioning the meaning of "launch speed" and whether it implies a parabolic trajectory. Others express familiarity with the Atwood machine but seek clarification on how to approach the height calculation for the lighter mass.
The conversation is ongoing, with participants exploring different interpretations of the problem. Some have provided calculations for acceleration and time, while others are questioning the implications of the hint regarding launch speed. There is no explicit consensus yet, but the discussion is productive.
The original poster mentions that they are accustomed to questions focusing on acceleration and forces, indicating a potential gap in understanding how to apply these concepts to the height of the lighter mass. The setup includes specific heights for the masses and the pulley, which may influence the interpretation of the problem.
laurs
The two masses are each initially 2.60 m above the ground, and the massless frictionless pulley is 10.00 m above the ground. The masses are m1 = 1.71 kg and m2 = 4.59 kg. What maximum height does the lighter object reach after the system is released?
(Hint: First determine the acceleration of the lighter mass and then its velocity at the moment the heavier one hits the ground.
This is its "launch" speed. Assume it doesn't hit the pulley.)
a = (m2-m1)(g)/(m2+m1)
vf^2 = vi^2 + 2ad
Fnet = ma
Fg = mg
Magnitude of acceleration of system:
a = (4.59kg - 1.71kg)(9.81N/kg)/(4.59kg + 1.71kg)
= 4.48 m/s^2
Velocity of lighter mass when heavier one hits the ground:
vf^2 = vi^2 + 2ad
= 0 + 2(4.48m/s^2)(2.60m)
vf = 4.83 m/s [up]
I am not sure what to do from here? I don't really understand what the hint means by launch speed, like is the mass flying out of the pulley into a parabolic trajectory?
laurs said:
Homework Statement: The two masses are each initially 2.60 m above the ground, and the massless frictionless pulley is 10.00 m above the ground. The masses are m1 = 1.71 kg and m2 = 4.59 kg. What maximum height does the lighter object reach after the system is released?
Homework Equations: a = (m2-m1)(g)/(m2+m1)
vf^2 = vi^2 + 2ad
Fnet = ma
Fg = mg
= 4.48 m/s^2
vf^2 = vi^2 + 2ad
vf = 4.83 m/s [up]
Hello, @laurs .
:welcome:
It's helpful to include all information in the body of your post, even if it's also included in thread's title.
Many of us are familiar with Atwood's machine. (Atwood system as you refer to it.) However, the point at which you are puzzled, indicates that you may not be familiar with it.
Is this the case?
Hi @SammyS
I am familiar with the machine, however am not accustomed to seeing questions asking for the height of the lighter weight. Most of the questions ask about the acceleration or the forces acting on the weights, which is a simple calculation, but I don't really know how to approach this one. I have been able to calculate time as well, assuming initial speed is 0, using the vf = vi + at, getting a value of t = 1.077s, but still am unsure how to approach the projectile portion of the question.
laurs said:
Hi @SammyS
As for the point you're stuck on:
The direction of "launch" is vertically upward at a distance of 5.20 m above the ground. The pulley is not involved. It's 10.00 m above the ground.
If an object is launched vertically with some initial speed, how high above the launch point will it get before it begins descending?
  • · Replies 19 ·
17K
