Why Does the Fourier Transform of Autocorrelation Equal the ESD?
  • Thread starter Thread starter dionysian
    Autocorrelation
The discussion centers on the relationship between the Fourier transform of the autocorrelation function and the energy spectral density (ESD) of the original signal, referencing the Wiener-Khinchin theorem. This theorem states that the power spectral density (PSD) is the Fourier transform of the autocorrelation function, highlighting that a rapidly decaying autocorrelation indicates high-frequency components in the signal. The conversation emphasizes the intuitive understanding of this relationship, particularly how a sharply peaked autocorrelation results in a broad spectrum. Participants suggest consulting textbooks for a deeper mathematical derivation and further insights into the theorem's implications in various fields. Overall, the discussion underscores the significance of the Wiener-Khinchin theorem in signal processing and related disciplines.
dionysian
Does anyone here have a good explanation of why the Fourier transform of the autocorrelation function equals the ESD of the the original signal. It kind of make sense intutively because functions that have a autocorrelation that drops of quickly are high frenquency and the Fourier transform of that resulting function will obviuosly have a wide bandwidth but it seems like there should but a analytic derivation of this.
Please be careful: ESD and PSD (energy and power spectral density) are not interchangeable.
You are inquiring about the Wiener-Khinchin theorem, which states that the PSD is the Fourier Transform (FT) of the autocorrelation function (and vice versa). Here is an online mathematical derivation:
http://mathworld.wolfram.com/Wiener-KhinchinTheorem.html"
The W-K is intuitively reasonable. It predicts, for instance, that a sharply peaked autocorrelation function R transforms to a broad power density spectrum. Think about a random noise signal for which R is a delta function; the FT of a delta is a uniform spectrum, and indeed random noise has a white spectrum. Other examples are also easily imagined.
I recommend that you check out the discussion in a textbook for more details. The W-K theorem is discussed in every text on Fourier transforms, signal processing, and if you are a physicist, statistical mechanics (because of the interest in characterizing random fluctuations).
Ahhh haa... I just found that in one of my books. Thanks. I just needed someone to point me in the right direction.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
