Automotive Radiator Sample Calculations Help
The discussion revolves around calculating the cooling requirements for a car radiator linked to a 325 horsepower engine. Key points include the need for typical inlet and outlet coolant temperatures and coolant volumetric flow rates for peak conditions. The complexity of engine cooling systems is highlighted, noting that they must manage heat beyond what is expelled through exhaust gases. The project is part of a car restoration effort, with the participant seeking guidance on quantitative analysis and relevant equations for radiator selection. Additional resources and web searches are suggested for further information on sizing and designing automotive radiators.
Messy Jesse
Hi all,
As part of a school project, I'm attempting to demonstrate some sample calculations of a car radiator and I'm a little lost. I'd like to demonstrate some cooling requirements for the peak power output of my car engine: 325 horsepower at 4400 RPM.
Can anyone offer any guidance as to how to obtain sample values for the max conditions:
Typical inlet and outlet coolant temperatures?
Coolant volumetric flow rate?
To be honest, I think you need to find another project. The problem with your proposed project is that the cooling of the engine is based upon the residual heat transfer to the engine assembly of that part of the combustion heat that is not removed by the engine exhaust gases. So there is no good way to determine how the removal of that heat is split between the exhaust discharge and the engine's cooling system.
Automobile engine cooling systems are designed to be able to remove more heat than is required to maintain the desired engine operating temperature under the anticipated worst case operating conditions and then a temperature sensitive thermostat controls the coolant flow rate through the system to maintain the engine at the desired operating temperature regardless of the variations in ambient air temperature or engine horsepower being generated at any given time.
Thanks for the reply.
This project is actually part of a larger project involving the restoration of a car. As just a small part of it, we'll be ordering a new custom radiator to mate with his engine. In reality, I'll be leaving the radiator designing and building to the pros at a custom rad shop. In the meantime, we're writing reports and I've been asked to perform some type of engineering / quantitative analysis to keep in mind for rad selection. So really, I'm looking for any type of quantitative analysis or relevant equations to convince my professors I know what's going on in the radiator. Sort of lost as to what direction to take. It doesn't need to be very involved, it can be general stuff.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
11K
