Autonomous Differential Equations: Equilibrium Solution and Deviation Equation
  • Thread starter Thread starter Townsend
The discussion focuses on solving the differential equation dy/dt = ay - b, specifically finding the equilibrium solution y_e and the deviation equation Y(t). The equilibrium solution is identified as y_e = b/a, which is valid only when a < 0, ensuring the solution does not diverge. The deviation from equilibrium is expressed as Y(t) = y - y_e, leading to the differential equation dY/dt = aY. Participants clarify that the behavior of the system depends on the sign of 'a', emphasizing the importance of understanding the equilibrium concept in this context. Overall, the thread highlights the need for clarity in interpreting the equilibrium solution and its implications for the differential equation's behavior.
Townsend
The problem is
Consider the differential equation dy/dt=ay-b.
a) Find the equilibrium solution y_e.
b)Let Y(t)=y-y_e; thus Y(t) is the deviation from the equilbrium solution. Find the differential equation satisfied by Y(t).
For part a I am confused as to what is meant by y_e.
The general solution is
y=Ce^{at}+\frac{b}{a}
I thought that the equilibrium is just the value that will be approached as t increases without bound. So in this case it depends on the values of a. If a>0 then there is no equilibruim solution. How can I answer part a then?
So without anywhere to go I made the assumption that y_e is meant to mean the y(e)=y_e in which case I come up with.
Ce^{ae}+\frac{b}{a}=y_e
So if this in fact the equilibrium solution y_e then for part b I have
Y(t)=y-y_e
Y(t)=Ce^{at}+\frac{b}{a}-\left( Ce^{ae}+\frac{b}{a} \right)
Y(t)=ce^{at}-ce^{ae}
Which is really like any our first diff eq but in this case the \frac{b}{a}=-ce^{ae} But the constant C makes our value for b/a unknown. Obviously I have something wrong here and I think its because I do not understand what the question is really asking.
Thanks for any help
This part
Y(t)=y-y_e
is definitely wrong.You made a point.The general solution to the equation
y(x)=Ce^{at}-\frac{b}{a}
must not diverge for asymptotic behavior...Which means that "a" must be negative...Find the equilibrium solution and then the function expressing the "deviation" from equilibrium...
Daniel.
PS.The diff.eq. will b very simple...
Ok, well if know that a<0 then the equilibruim is going to be \frac{b}{a}
So then Y(t)=Ce^{at}
and
\frac{dY}{dt}=ay
You said the diff.eq. will be b,I am not sure how you got that.
sorry, I am trying to understand.
Thanks
That "b" was "be"... :-p You got the picture. :smile: The diff.eq.may be put under the form which would definitely show the asymptotic behavior,namely make the substitution
a\rightarrow -|a|
Daniel.
