How Is Average Force Calculated in Physics Problems?
  • Thread starter Thread starter looi76
    Average Forces
The discussion focuses on calculating average force in a physics problem involving a ball's motion. The user has determined the distance traveled by the ball in the first 0.40 seconds to be 0.8 meters and calculated the change in momentum as 0.19 Ns. However, they question the discrepancy between their momentum calculation and the textbook's answer of 0.35 Ns. Clarification is sought regarding the timing of the ball's contact with the surface as indicated in the provided diagram. The conversation emphasizes understanding the relationship between distance, momentum, and force in physics problems.
looi76
http://img100.imageshack.us/img100/1867/physicsp25wz8.png
Use data from Figure to determine,
(a) the distance traveled by the ball during the first 0.40s,
(b) the change in momentum of the ball, of mass 45g, during contact of the ball with the surface,
(c) the average force acting on the ball during contact with the surface.
(a) 0.8m
(b) Change \ in \ momentum = mv - mu
= (45 \times 10^{-3} \times 4.2) - (45 \times 10^{-3} \times 0)
= 0.19Ns
Answer in textbook is 0.35Ns, where did I go wrong?
Where on the diagram does contact with the surface begin and end?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
