Average Net Force on a Car 0-60mph: Weight Comparison
To calculate the average net force on a car accelerating from 0 to 60 mph, first determine the car's acceleration using the formula a = (final velocity - initial velocity) / time. Once the acceleration is known, apply Newton's second law, F = ma, to find the net force, where m is the mass of the car. The net force can then be compared to the car's weight, calculated as weight = mg, where g is the acceleration due to gravity. Understanding these equations is crucial for solving the problem effectively. This approach will provide a clear comparison between the average net force and the weight of the car.
shiney612
What is the average net force on a car during a zero to 60mph (0 to 30m/s) acceleration? Compare this force to the weight of the car.
I just don't know what equations to do and need help to figure out what to do.
Hi shiney612, welcome to PF.
Can you find the acceleration of the car? What equation(s) would you use for that?
Once you have the acceleration, can you find the force? What equation does that involve?
