Average photon energy from a galaxy cluster
throneoo
I want to calculate/estimate the average photon energy from a galaxy cluster incident on the mirror of a X ray telescope (Chandra to be specific) . The cluster has redshift z and at constant uniform temperature T
Specific Intensity of thermal bremsstrahlung : I∝Λ(ν)*T-1/2*exp(-hν/kT)
z=(νemittedobserved)/νobserved
At high temperatures the X ray emission is dominated by thermal bremsstrahlung.
The average photon energy should be found via the integral ( ∫ I dν ) / ( ∫ [I/hν] dν ) from ν=0 to infinity, then that energy should be divided by (1+z) due to the redshift, but since the full expression is not given in the problem, it's not really a viable approach.
Therefore I'm left with the approximation approach. I think <E>=hv≈kT should be good enough since in the x-ray region, photons' momentum and energy is comparable to that of electrons, and that it seem to be the value at which I is equal to its average value (referring to the curve below).
The classical spectrum (valid for moderate temperature): https://upload.wikimedia.org/wikipe...ower2.svg/731px-Bremsstrahlung_power2.svg.png
Galaxies radiate a lot more visible light than x-rays, and those two cannot be described by a single temperature. I don't think starting the integration at 0 will lead to a useful result.
You'll need a temperature value if you want to follow the approach of thermal emission. And probably the sensitivity range of Chandra, unless you really care about all the low-energetic photons.
Okay so I can effectively put the sensitivity range of chandra in my integration, then I~exp(-x) with the range. However exp(x)/x is still a nasty integral so I'll have to look up values of exponential integral.
And by thermal emission do you mean black-body emission?
If it is not black-body-like, you need to know more about the radiation.
I think that would be the braking radiation as given in OP
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
