Calculate Average Velocity: Get Help Here!
To calculate average velocity, the correct formula is Δx / Δt, not Δv / Δt. The user is struggling to find the exact position at t = 5, which lies between 40 and 60 on the graph. It is suggested to measure the graph accurately rather than estimating, as the graph is linear and indicates a constant velocity. One user points out that the values at t = 4.5 and t = 6 can be used to calculate the velocity at t = 5, which should yield a different result than the incorrect 6.3 previously calculated. Accurate measurement and understanding of the graph are crucial for solving the problem correctly.
sfgradv
Does anyone know how to do this? Thanks!
Yes I do, and you're welcome.
On this forum, you are expected to show your work so we can help you progress. We will not give you the answer. SO, what have you done so far? Can you at least tell me what is the equation for the average velocity?
delta v over delta t. i don't no the velocity for t = 5.
hello I am guessing since ave velocity is m/s you can get the velocity by looking at the y-axis aka the position in meters. Then you have the components for solving the problem, right? Others-feel free to correct me if I'm wrong.
the thing is it doesn't tell u exactly what the position is at t = 5. it is between 40 - 60 and it said not to eyeball it. i thought it was 45 and i used it in the formula and got 6.3 and got the wrong answer. so what should i do now?
That's the formula for average acceleration. Average velocity is \Delta x / \Delta t.
yea sorry. i meant delta x over delta. i still don't no how to do it and its 3 am now! i have to go to sleep. ahhhhh. can someone please help me quick?
Get out a ruler, and carefully measure (a) the distance between the x = 40 and x = 60 lines on the graph, and (b) the distance between the x = 40 line and the point where the graph intersects the t = 5 line. That will give you enough information to calculate x at t = 5 (more precisely, x - 40).
Don't worry about t=5. Since the graph is a straight line, the velocity is a constant there. It looks to me like t= 4.5, x= 60 and when t= 6, x= 20. velocity at t= 5 should be (20- 60)/(6-4.5) (which is no where NEAR 6.3!)
