Avoiding dividing by 0 in an equation
  • Thread starter Thread starter Crusty
Crusty
What was the method for modifying an equation to avoid dividing by zero?
I think it involved adding 1 somewhere, then removing the error that creates later.
For example,
a / b = c
It is possible that one of the values placed in the b variable could be 0. How would the equation be modified so that dividing by zero wouldn't occur?
Mathematics news on Phys.org
If b is a variable that could be zero, then a/b=c doesn't even make sense in the first place.
What is the context of this?
Its a commonly left out detail, sometimes considered obvious, sometimes completely forgotten. When you have a fraction a/b, b can not equal zero. Its a restriction placed on b in order for the division to be defined.
The only way to "modify" the equation a/b= c so that you can avoid dividing by 0 is to remove the division entirely: a= bc.
Of course there's the possibility that in the limit a->0 and b->0 ; a/b equals a real number and the eqn. makes sense. Hard to tell without context.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
I'm interested to know whether the equation $$1 = 2 - \frac{1}{2 - \frac{1}{2 - \cdots}}$$ is true or not. It can be shown easily that if the continued fraction converges, it cannot converge to anything else than 1. It seems that if the continued fraction converges, the convergence is very slow. The apparent slowness of the convergence makes it difficult to estimate the presence of true convergence numerically. At the moment I don't know whether this converges or not.
