Axis of Rotation: Rotate About Other Axes?
The discussion centers on the concept of rotation about different axes, particularly in the context of rigid bodies. Participants explore whether a body rotating about one axis can also be considered to rotate about other parallel axes, and how this relates to concepts like angular momentum and moment of inertia.
  • Some participants propose that a body rotating about a specific axis may also be described as rotating about any parallel axis, though this raises questions about the nature of rotation.
  • Others argue that the terms "rotate" and "revolve" have distinct meanings, as illustrated by the Earth’s rotation about its axis and its revolution around the sun.
  • One participant notes that while a moving body has angular momentum with respect to any stationary line, it has only one instantaneous axis of rotation where all elements of the body share the same angular acceleration.
  • Another participant suggests that a rigid body maintains a constant distance from a single axis during rotation, implying a limitation on the number of axes about which it can be considered to rotate.
  • There is a discussion about the concept of instantaneous axes of rotation, particularly in the context of a rolling disc, where multiple axes may be considered depending on the frame of reference.
  • Examples are provided, such as a lever rotating about a pivot and a rocket changing orientation, highlighting the complexities of describing motion in terms of fixed points versus center of mass.
Participants express differing views on whether a body can be considered to rotate about multiple axes simultaneously. Some agree that it is possible to describe motion about parallel axes, while others emphasize the constraints of a single instantaneous axis of rotation. The discussion remains unresolved with multiple competing views.
Limitations include the dependence on definitions of rotation and revolution, as well as the assumptions regarding fixed points and instantaneous axes. The discussion does not resolve the complexities involved in modeling motion for different scenarios.
aniket7tomar
Does a body rotating about an axis also rotate about any other axis?
Eg. Cars on a racetrack may be rotating about a vertical axis passing through the centre of the track but can they also be considered to be rotating about a vertical axis passing through the spectators' stand?
Specific question - no. In general the terms rotate and revolve have different meanings. The Earth rotates about the axis defined by the north and south poles. The Earth revolves around the sun.
I think you misunderstood the question or i am unable to understand the reply...
What i asked was that in the fig. If body b is rotating about axis aa' then can we say that there can be an axis mm' parallel to aa' about which the body's motion can be described as rotation?
Can that happen with any axis parallel to aa'?
The moment of inertia will be different if you change the axis of rotation.
But while a moving body will have angular momentum wrt any stationary line, it will only have one instantaneous axis of rotation - this is the axis for which every element of the body has the same angular acceleration.
I was going to say that if a rigid body is rotating about an axis, then each point on the body remains the same distance from the axis. Surely this can be the case only with a single axis.
I was under the impression that i understood your answer but then later i thought about how when a disc is rolling 'purely' we can consider it to be rotating about an instantaneous axis passing through the pt. in contact with the ground as well as a moving instantaneous axis through the centre of mass?
Pls. tell
a7t: I see what you mean. My post exemplifies fools rushing in where angels fear to tread. I'd say that the instantaneous rotation axis was the line of contact with the ground, but it is certainly true that the velocity of each point on the disc can be constructed by adding a constant 'forward' velocity to a velocity due to rotation about a stationary axis through the centre of the disc. Nonetheless, in our ordinary frame of reference, I'd say it was not correct to claim that the disc is rotating about its centre. I suspect this is controversial. Let's hope you get more replies to your interesting question.
Yes.
You can pick any arbitrary point on (or even off of) the body and describe the 6 DOF motion of the body as a combination of translational motion of that selected point plus rotational motion about an axis that passes through that point.
A couple of specific examples:
1. A lever rotating about a pivot point, or a door that opens on a hinge. Here there is a fixed point (or set of fixed points) on the rotating object that doesn't undergo translation. It oftentimes make more sense to describe the behavior in terms of pure rotation about this fixed point than describing it in terms of translation of the center of mass and rotation about the center of mass. If you do the latter, you need to add constraint forces / constraint torques to the description so as to keep the fixed point fixed.
2. A rocket that goes from a vertical orientation on the ground to a horizontal orientation ten minutes later, in the process expelling 95% of its mass. With a center of mass description, you need to account for the fact that the center of mass moves within the rocket if you want to accurately model where that rocket will be after that ten minutes. There are different uglinesses that come into play a fixed point description (e.g., translation of / rotation about the nose of the rocket).
  • · Replies 32 ·
