Back EMF: Explaining the Counter Voltage Induced by Change in Current
Back emf, represented by the equation ε_b = -L(dI/dt), is the counter voltage induced by a change in current in an LR circuit, where ε_0 + ε_b = IR. The discussion highlights that applying back emf alters the rate of current change, leading to potential confusion about its modeling. It clarifies that back emf is not applied but generated due to increasing current, thus affecting the overall circuit dynamics. The relationship between applied emf, resistance, and induced emf is encapsulated in the equation E = IR + L(dI/dt), which can be solved to find the steady current over time. Understanding back emf as a differential phenomenon simplifies the modeling process.
randomafk
Hi,
I have a question about back emf
So, my understanding of back emf (\epsilon_b=-L\frac{dI}{dt})is that its the counter voltage that's induced by change in current, whether it be from a battery or magnetic field (\epsilon_0). We can model this as an LR circuit where \epsilon_0 +\epsilon_b=IR
But when we add the back emf, don't we change the value of dI/dt? i.e. if we differentiated the equation we'd be left with
\frac{d\epsilon_0}{dt}-L\frac{d^2I}{dt^2}=R \frac{dI}{dt}
And then, the time derivative of current would be offset by an additional 2nd derivative of current (multiplied by negative L). I'm assuming we calculated change in current as \frac{dI}{dt}=\frac{1}{R}\frac{d\epsilon_0}{dt}, hence the offset.
Does this model then only hold for cases where current changes linearly/not at all? And if this is correct, how would we model it for such cases where current changes with respect to 2nd or higher derivatives of time?
If the resistance in the circuit = 0 then the induced emf,e, must be equal to the applied emf, E,
This means that e = E = -L.dI/dt
This means that the current will increase at a constant rate of dI/dt = E/L
If there is resistance in the circuit then the emf appearing across the L = E - Ir
This means that L.dI/dt = E - Ir
Thanks for the clarification. So the back emf and IR must add up to the applied emf.
My confusion/question still remains though.
That is, if we apply a back emf don't we change the rate at which current changes over time (if it has a nonzero second derivative)? If so, wouldn't this induce another back emf because the "first" back emf has induced a change in current?
Would we then model this as a summaiton of some sort? i.e.
\epsilon_b=-L(\frac{dI}{dt}-\frac{1}{R}\frac{d^2I}{dt^3}+\frac{1}{R^2}\frac{d^2I}{dt^3}-...)
I think your confusionis inthe phrase '...if we apply a back emf...'
A back emf is not something that is applied.
When a battery (emf) is connected to a circuit and the switch is closed the current begins to increase. AN Increasing current will result in an induced (back) emf as a result of any inductance in the circuit.
The induced emf = -LdI/dt (it is not an applied emf,it is caused by the increasing current)
If there is resistance in the circuit you are correct to state that Ir + induced emf = applied emf, E.
E = IR + LdI/dt
the solution to this equation is
I = Io(1-exp-(Rt/L))
After a long time the final (steady)current will be Io and the initial rate of increase of current will be = E/L
E = IR + LdI/dt
Oh, okay. Yes, that makes sense.
I feel sort of silly now. The backemf is generated differentially so it's just a simple differential equation to solve for it..
Thanks!
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
I passed a motorcycle on the highway going the opposite direction. I know I was doing 125/km/h. I estimated that the frequency of his motor dropped by an entire octave, so that's a doubling of the wavelength. My intuition is telling me that's extremely unlikely. I can't actually calculate how fast he was going with just that information, can I? It seems to me, I have to know the absolute frequency of one of those tones, either shifted up or down or unshifted, yes? I tried to mimic the...
