Backgating (chip) advantages.
  • Thread starter Thread starter Hyo X
Backgating and electrochemical gating are two methods for controlling conducting polymers on chips, each with distinct advantages and disadvantages. Backgating applies an electric field from beneath the substrate, while electrochemical gating alters the local electronic environment in solution. The uniformity of the electric field in backgating can be challenging, especially in thicker integrated circuits, which typically range from 350 to 500 microns. Thinning the wafer can improve control over surface potential but is a complex and costly process. Understanding these gating techniques is crucial for optimizing the performance of conducting polymers in electronic applications.
Hyo X
Several ways to gate a conducting polymer on a chip.
Backgating, electrochemical gating.
What is backgating and what advantages/disadvantages would it have?
How does electrochemical gating work?
specifically regarding homogenous charge distribution or uniform electric field applied.
By "gating", do you maybe mean "coating" or "plating"? Where have you seen the term "gating"?
Gating as in for a transistor.
A three point probe with a source, drain, and a gate to apply a potential across the channel.
In this case, I was saying, using a conducting polymer (or polymer film) as the channel between source and drain.
Backgating would be applying the electric field from under the substrate (i.e. the back)
electrochemical gating involves changing the gate potential on the channel by altering its local electronic environment in solution.
What are the advantages and disadvantages of each?
Can you expect the electric field applied by a backgate to be uniform across the channel?
Would ionic liquid have negative effects on the channel?
thanks
Typically integrated circuits are 350 to 500 microns thick so it is difficult to control a surface structure using a backside contact. Typically if the backside of the wafer is contacted at all, it is grounded with a conductive epoxy.
If you want to control the surface potential of the semiconductor in any substantive way, you will have to thin the wafer, which is both challenging and expensive, but is done in practice in some cases.
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
