Backwards Derviative? Am i seeing this right?
  • Thread starter Thread starter 1joey1
The discussion centers on understanding the concept of a "backwards derivative," which refers to integration. The participant seeks clarification on a step involving integration, specifically the formula for integrating x^n, which is [x^(n+1)]/(n+1). They explain that this process helps find the area under a curve, relevant to calculating work in Joules. The participant plans to attend office hours for further assistance and acknowledges the challenge of keeping pace with both calculus and physics classes. Overall, the conversation highlights the importance of grasping integration in relation to derivatives.
1joey1
I believe if I am seeing this right, my professor does a backwards derivative in the last step? He didn't quite explain it in class, and I'm going to be attending office hours on monday, if anyone could fill me in on the last step or so I'd be appreciative.
It is integration. The rule of integration is,
Int.(x^n) = [x^(n+1)]/(n+1).
It is called backward derivative because
derivative of x^(n+1) = (n+1)*x^n
It's an integral, or a backwards derivative as you suggest shown by that fancy squiggly he's got there. Essentially it's used when you're trying to find the area under a curve. In your case the area under the curve is the work in Joules.
When you have to calculate the integral of x^n, the general formula is x(^(n+1))/(n+1). So the integral of the first term 3x^2 becomes 3/3 x^3. For the last term, (+10) its the same as writing 10*x^0 (because x^0 is 1). so plug it into the equation I showed you and you'll get the same answer he got.
Thanks guys i really do appreciate it, my calculus class is about 2 weeks behind my physics class so it's constantly catch-up for me. Thanks and i'll be sure to read into integration this weekend.
