What is the Optimal Angle for Maximum Torque in a Balancing Torque Problem?
  • Thread starter Thread starter Physics103
    Torque
The optimal angle for maximum torque in a balancing torque problem is 90°, as this configuration provides the highest torque. When the angle between the rod and the rope is 65°, using sin(65°) for the rope tension component normal to the rod is appropriate. There was confusion regarding the use of sin(25°), but it was clarified that sin(65°) should be used instead. The discussion emphasizes the importance of correctly identifying the angle to calculate torque effectively. Understanding these angles is crucial for achieving maximum torque in practical applications.
Physics103
Thx for the help everyone :D
If the angle between rod and rope is 65°, then using sin (65°) for the component of rope tension normal to the rod is correct.
Edit: Sorry about that, I was thinking of cos (25°) which would yield the same as sin (65°).
Wait so in the above equation using sin 25 would be the correct one?
NO, use r ft sin 65 , like you did.
if the angle between the rod and the wire had been 90,
it would have provided maximum torque possible (not zero).
