Ball Drop Phenomenon: Designing a Multi-Ball System for Maximum Elevation
  • Thread starter Thread starter emadkarimianrad
    Astro
The discussion centers on the ball drop phenomenon, where a smaller ball stacked on a larger one can achieve greater elevation when dropped onto a hard surface. Participants are encouraged to investigate this effect and design a multi-ball system, using up to four balls, to maximize the height of the top ball. Relevant resources are shared to aid in understanding the physics behind the phenomenon. There is a question raised about whether this topic relates to the IYPT question for 2008. The exploration of this phenomenon could lead to interesting insights in physics and engineering design.
emadkarimianrad
sombodyyyyyyyyy hellllllllllp me
Astroblaster:
When a large ball is dropped, with a smaller one stacked on top of it, onto a hard surface, the smaller ball will often rise much higher than it would if dropped onto the same surface by itself while the larger ball hardly bounces at all. Investigate this phenomenon and design a multiple-ball system, using up to 4 balls, that will reach the greatest elevation of the top ball.
ahh. is this the IYPT question for 2008. ?
