Ball dropped through a tunnel through the earth.
  • Thread starter Thread starter PhysicsStudnt
    Ball Earth
A body of mass m dropped through a tunnel to the Earth's center experiences a change in potential energy (PE) that equals its gain in kinetic energy (KE). The initial PE at the surface is calculated as |-GMm/R|, leading to a velocity formula of v = √(2GM/R). However, a textbook states that the PE at the center is -(3/2)(GMm/R), indicating a discrepancy in assumptions about where potential energy is zero. The gravitational force acting on the body varies with distance r from the center, as only the mass within the sub sphere of radius r contributes to the gravitational attraction. To resolve the problem accurately, one must consider the changing mass M(r) as the body descends.
PhysicsStudnt
A tunnel is drilled from the surface of the earth(mass assumed to be M and radius to be R) to its center . A body of mass m is dropped from the surface to the center through the tunnel. What will be the velocity with which the body of mass m will hit the tunnel.
Loss in PE = Gain In KE
Loss in PE = PE at surface - PE at center of earth.
= |-GMm/R - 0|
1/2 mv[2] = |-GMm/R|
v = √(2GM/R)
But in a textbook , the PE at the center of Earth is given to be -(3/2) (GMm/R)
what is the right way of approaching the problem.
The point where the potential energy is zero, is arbitrary. You assumed it to be the centre of the Earth which is not in agreement with problem's assumption. Of course you can solve the problem with your current assumption too.
Let's assume that ##R## is the radius of the planet, and ##r## is the distance between the body and the center.
Then the attractive force is not just ##F=-\frac{GMm}{r^2}##.
The value of ##M## that you should use varies with ##r##, since we're inside the planet.
The ##M## that contributes is the mass in the sub sphere that is still between you and the center of the planet. To calculate it, we need to assume for instance that the mass density is constant.
What would the mass ##M(r)## of the sub sphere of radius ##r## be?
