What is the derivation of centripetal acceleration on a hypothetical planet?
Centripetal acceleration is derived from the difference between the gravitational acceleration at the equator and the observed acceleration of an object dropped, which in this case is 10.00 m/s² minus 9.70 m/s², resulting in 0.3 m/s². This value represents the centripetal acceleration due to the planet's rotation. To understand this conceptually, one can visualize the change in velocity over a small time increment, incorporating a vector triangle that illustrates the relationship between linear and centripetal acceleration. The cosine factor, approximated to 1, simplifies the derivation of the centripetal acceleration formula. Understanding this derivation is crucial for solving similar problems in physics.
rrosa522
Imagine another planet with an acceleration of 10.00 m/s^2 at its equator when ignoring the rotation of the planet. The radius is 6.2 x10^6 m. An object dropped at the equator yields an acceleration of 9.70 m/s^2. Determine the length of 1 day on this planet.
My teacher taught me how to solve this question, but there is just one step I don't understand
10.00m/s^2 - 9.70m/s^2 = 0.3m/s^2 (centripetal acceleration)
why does subtracting these two values give us the centripetal acceleration??
On a test, if I get a similar question I know I have to subtract the two values, but I really want to learn the reason behind it.
Do you know how to derive the formula for centripetal acceleration in terms of velocity, using a vector triangle showing the change in velocity over a small increment of time ##\delta t##? A similar construction can be used to justify the above formula. There's a ##\cos\delta\theta## factor in there that is approximated by 1 to get the above formula.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
