Baseball Problem: Does a Ball Hit the Roof? Answer Here!
  • Thread starter jfeelz33
  • Tags
    Baseball
In summary, the conversation is about a calculus problem involving a baseball pitcher throwing a ball in a domed stadium with a 200-foot roof. The person is struggling with finding the maximum height the ball reaches and is seeking help with writing an expression for the height as a function of time using integrals.
jfeelz33
This is part of a calculus test and I am clearly missing something because this should be an easy problem: A baseball pitcher is having fun with the fans. He can throw a ball vertically froma point 6 feet above the ground at 75 miles per hour (110 ft/sec). He is standing in a domed stadium with a roof 200 feet above the ground. Does the ball hit the roof? Justify your answer.
We are currently doing integrals and just finished derivatives if that's any help. Any help would be appreciated, thanks.
I sadly don't have one.
Clearly you need to figure out the maximum height the ball reaches. Can you write an expression for the height as a function of time?
You can start with the acceleration due to gravity and integrate if you like.
I would approach this problem by first defining the variables involved and setting up the relevant equations. The key variables here are the height of the ball, the height of the roof, and the initial velocity of the ball. From these, we can use the equations of motion to determine the position of the ball at any given time.
Using the equation h(t) = h0 + v0t - (1/2)gt^2, where h(t) is the height of the ball at time t, h0 is the initial height, v0 is the initial velocity, and g is the acceleration due to gravity, we can set up an equation for the height of the ball at any given time.
In this problem, we are given that the initial height (h0) is 6 feet, the initial velocity (v0) is 110 ft/sec, and the height of the roof is 200 feet. We can also assume that the ball is thrown straight up, so the acceleration due to gravity (g) is negative and equal to -32 ft/sec^2.
Now, to determine if the ball hits the roof, we need to find the time at which the height of the ball is equal to the height of the roof. We can set up the following equation:
200 = 6 + 110t - (1/2)(32)t^2
Solving for t, we get t = 4.08 seconds. This means that after 4.08 seconds, the height of the ball will be equal to the height of the roof. Therefore, the ball does hit the roof.
In terms of calculus, we can also use the concept of limits to prove this. The height of the ball at any given time can be represented by a function, h(t), which we can take the derivative of to find the velocity of the ball at any given time. We can then take the limit of this velocity function as t approaches 4.08 seconds to determine the exact moment when the ball hits the roof.
In conclusion, using both equations of motion and calculus, we can determine that the ball does hit the roof in this scenario. It is important to always justify our answers with relevant equations and logical reasoning in scientific problems.
1. What is the "Baseball Problem: Does a Ball Hit the Roof?"
The "Baseball Problem: Does a Ball Hit the Roof?" refers to the scenario in which a baseball is hit high into the air and comes into contact with the roof of a stadium or other structure. This can pose a challenge for players and officials in determining the outcome of the play.
2. How is it determined if a ball has hit the roof?
In most cases, officials will use their judgement to determine if a ball has hit the roof. However, in some cases, technology such as video replay may be used to make an accurate determination.
3. What happens if a ball hits the roof during a game?
If a ball hits the roof during a game, the outcome of the play will depend on the specific rules of the league or organization. In some cases, it may be considered a dead ball and play will stop, while in other cases, it may still be in play.
4. Does a ball hitting the roof affect the outcome of the game?
The effect of a ball hitting the roof on the outcome of the game will depend on the specific rules and circumstances of the play. In some cases, it may result in a change in the score or the continuation of the play, while in other cases, it may have no impact on the game.
5. Are there any specific rules or guidelines for when a ball hits the roof?
There are no universal rules or guidelines for when a ball hits the roof, as it will depend on the specific league or organization. However, most will have specific rules in place to address this situation and ensure fair play for all teams.
  • General Math
17K
