How Do You Calculate the Fourth Displacement in Vector Addition?
  • Thread starter Thread starter Fireworkslvr
    Vectors
To calculate the fourth displacement in vector addition for the spelunker's journey, break each vector into its x and y components using the formulas for cosine and sine. The sum of the x-components and the y-components of all four displacements must equal zero, allowing for the calculation of the fourth vector's components. A graphical approach, such as sketching the vectors, can also aid in visualizing the problem and confirming numerical results. Understanding the angles and directions of the first three displacements is crucial for accurate calculations. This method ensures the spelunker returns to the starting point after the fourth displacement.
Fireworkslvr
" A spelunker is surveying a cave. he follows a passage that goes 210 meters straight west, then 180 meters in a direction 45 degrees east of west, then 110 meters at 60 degrees east of south. After a fourth unmeasured displacement he finds himself back where he started. Use the method of components to determine the fourth displacement (magnitude and direction). "
I have looked around for information on solving this, but am unsure about how to go about finding the other angles to find the magnitude or direction, and am not sure about finding the last dimension. I know I am supposed to show you that i have tried this and believe me I have, but I am new to physics and am pretty much confused on where to even begin this problem.
Thanks for all help.
break each vector into x-y components
x-comp = vector magnitude x cos theta
y-comp = v mag x sin theta
and then from the question you know that:
x1+x2+x3+x4=0
y1+y2+y3+y4=0
so solve for x4 and y4
x1+x2+x3+x4=0
y1+y2+y3+y4=0
Thanks, that helps alot!
Another nice way to do it (if you've got the time) is to solve it graphically, by drawing a scaled version of the problem out. Even if you end up solving it numerically, a sketch often helps by showing you roughly what you should be getting.
