Basic QM - Trying to catch up in a class
  • Thread starter Thread starter FrogPad
    Class Qm
The discussion revolves around a student struggling to catch up in a quantum mechanics class, specifically with a problem involving the wave function of an electron in a one-dimensional infinite square well. The student is tasked with expressing the wave function at time t and calculating energy values and their probabilities. They recognize that the wave function is derived from the Schrödinger equation but are unsure how to incorporate time dependence into their solution. A hint is provided, suggesting the use of the time evolution operator to express the wave function at time t. The conversation highlights the challenges of grasping quantum mechanics concepts and the need for guidance in applying theoretical principles.
FrogPad
I haven't taken one of the recommended courses for a class I am in, so I'm playing a little catch-up here.
Q: The wave function of an electron in a one-dimensional infinite square well of width a,x -> (0,a) at time t=0 is given by:
\psi (x,0) \sqrt{\frac{2}{7}}\psi_1(x) + \sqrt{\frac{5}{7}}\psi_2(x)
where \psi_1(x) and \psi_2(x) are the ground and first excited stationary state of the system respectively, \psi_n(x)=\sqrt{\frac{2}{a}}\sin (n\pix/a), \,\,\, E_n = n^2\pi^2 \bar h^2/(2ma^2), \,], n=1,2,...
a) Write down the wavefunction at time t in terms of \psi_1(x) and \psi_2(x).
b) You measure the energy of an electron at time t=0. Write down possible values of the energy and the probability of measuring each.
c) Calculate the expectation value of hte enrgy in the state \psi(x,t) above.
I am lost here. I am stuck on (a) right now, and really do not know where to go. To me it looks like \psi_n(x) is the wavefunction already solved from the schrodinger equation (with the boundary conditions 0 and a). So I need to express the total wavefunction in terms of two states psi_1, and psi_2. This to me seems like another condition that would come from a differential equation something with a time dependence. I am lost...
Would someone nudge me in a proper direction?
thanks,
Hint for 1. \psi (t)=U(t)\psi=e^{\frac{1}{i\hbar}tH} \psi
Daniel.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
